Lucas tail light + signal relocate DIY - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-15-2012, 12:46 AM   #1 (permalink)
Main Motorcycle: '06 T100
Bron-Yr-Aur's Avatar
Other Motorcycle: Kawasaki KXdirtshredder
Extra Motorcycle: '76 Tiger 750
Well, I searched and searched, and finally just pieced together what I could in order to do this job. It didn't take long to realize I was on my own for a lot of this. It seems almost weekly I see posts on the Lucas tail light, people wondering how to do it. (I was one of them) So I thought I'd post a little help. I know this is easy for a lot of you experienced guys. But many of us out there have trouble doing some stuff on our bikes when we don't receive, at least, a little bit of coaching.
I hope I'm not repeating a how-to on the Lucas light. If I am, sorry guys, move on.
I also noticed that most want to relocate their tail lights when they do this. I thought I'd maybe give people something to think about if they don't want to spend the $10 to $20 for the brackets. Of course, this isn't the only way to do this.
If anyone has better ideas, please post them here. Hopefully this will help future would-be fabricaters.
Part I: Lucas Tail Light
As you can see, the base of the light doesn't really match the curve of the stock fender. Depending on where you place it on the fender, this gap may even be visible with the rather thick base gasket in place. So I did a little taping on my light, and got the tools I needed (air grinder with sanding disk, air saw (for signal brackets) and vice grips (also for brackets)). Using masking tape, I marked where I needed to sand to:
The sanding left a very sharp edge, so a disc sander with 180 nicely broke the edge, preventing the light cutting through the gasket in time. I wanted my light a little higher on the fender so that the top of the light is level. If I had used the pre-existing holes in the fender, my light would have been pointing at the ground. So after much positioning and visually testing, I decided on a placement which yielded these holes (the 3 smallest holes are the ones I drilled):
Using the pre-existing top hole to feed my electrical wires through, I fitted and attached the light. For the electrical, I just used electrical connectors that can be found anywhere (the male/female type). Having already removed the lights and harness from the fender, I clipped the ends off (leaving them with the stock lights in case I ever needed to put them back or sell them) and attached the new ends. As for the ground for the tail light, notice the eyelet I attached on the harness. This is because NEITHER of the 2 wires on the tail light are a ground. The light itself is its own ground. But just attaching it won't work because the fender is not grounded to the frame well (or doesn't seem to be after much inspecting). That eyelet should be attached to 1 of the 3 bolts holding down the light. This will ground the light.
A previous post by Forchetto gave me the insight of how to differentiate the running/position/marker light wire from the actual brake light wire. Touch the base of the light (the ground) to the negative terminal of your battery. Touch each wire, one at a time, to the positive terminal. You'll see very easily. In this case, the black wire is the brake, the red is the position light. On the harness, blue is brake, red is position.
Here is the link to his post:
http://www.triumphrat.net/twins-talk...ail-light.html
Now, there are several ways to wire for the signals. We'll get to that later. But as for the tail light, this is the finished product underneath:
Part II: Signals
I really like the placement of the signals at the rear shock mount point, but... With my lowered bike, and keeping the back fender, I feared that with the lower profile of the lights, cars behind me would not see them if they were at any angle other than straight behind. So I opted to place them at the rear of the seat. (Not to mention they look pretty slick there, too)
I saw many brackets in many different places. I used book shelf brackets I found in a local home improvement store. Then, after removing the seat, decided to use 2 of the 4 pre-existing holes (I think used for grab rails? Not sure) So I just marked the brackets, placement of the attachment holes on top and on the side for the light mount. I drilled the holes with a unibit (some call them step bit) Cut them down and sanded the edges smooth and the visible face to accept better the paint:
Painted them up, and here we go
Ok the wiring. There are several ways to do this. I'm a person who will do 3 times the work to maintain originality, so I didn't want to cut up the wires of my harness. So I split the sheathing and ran the 4 signal wires back from halfway down the fender, then wrapped the sheathing back and taped it up like mad with electrical tape:
Had I to do it again, I would have probably just cut away the sheathing close to the connector, isolated the 4 wires, clipped them there, attached the connectors there and just left the 4 dead wires hanging at the back. But this is my first time, so I guess I'll allow myself one misjudge.
For those of you who don't have your manual, on my '06 Bonnie, the left rear signal hot is orange and right rear hot is brown. Blacks are grounds. I'm not certain of which years these colors were used. The manual has that info. If anyone needs help and has no manual, I'll be glad to help.
One more thing: The stock light comes with zinc-plated screws. If you will EVER drive your bike in the rain, please spend a little extra and get some stainless bolts/washers/nuts. I opted for the hex-keyed. I think they just look cleaner. If you're here in Jacksonville, I highly recommend "Threaded Fasteners Inc" A .70-.80 cent stainless bolt in Ace Hardware costs me around .08-.12 cents at TFI. Awesome guys. Super helpful, not only on prices but on application information. Very knowledgeable.
And so this is the finished product. Hope this helps any future fabricaters/electricians. I got this light from Bella Corse and I really like it. It's much sturdier than the stock plastic one.
Be nice guys with any criticism. I do appreciate it, though, when it's constructive. Any additional help or info will be appreciated, I'm sure, by future readers.
Bron-Yr-Aur Garage
Bron-Yr-Aur is online now   Reply With Quote
Old 02-15-2012, 02:41 AM   #2 (permalink)
Main Motorcycle: Jet Blk T100
kreemsicleT100,
excellent work, it looks great. I've recently picked up a T100 and really appreciate folks like yourself who take the time to thoroughly document and post your mods. Again looks great and thanks for showing us how it was done.
best
GD
GrinDrift is offline   Reply With Quote
Old 02-15-2012, 04:34 AM   #3 (permalink)
Legend
Forchetto's Avatar
Brilliant. Great post. We get asked about these lights constantly so this thread will really help.
Old 02-15-2012, 07:58 AM   #4 (permalink)
Wow thanks so much guys! It seems almost every time I do something, THEN I see something or talk to someone that helps me realize that there are better ways to do it. This one had me stressed for a few days before I started. I really appreciate this forum though, especially all the posts by Forchetto. They helped me a lot. Thanks again
Bron-Yr-Aur Garage
Old 02-15-2012, 04:00 PM   #5 (permalink)
Main Motorcycle: Triumph
Thanks for writing this up. The pictures and description is very helpful.
This is on my list of one of the first mods when I get my bike. I HATE the shameful stock lights and this will be the thread I turn to when I do this.
One note. If could add the link to Forchetto's thread (where you mention it) in your tutorial it would make it easier for folks to reference it.
Thanks again.
Cheers.
Brian
PS... what length shocks are you running in the photos above?
AtomicAddiction is offline   Reply With Quote
Old 02-15-2012, 04:26 PM   #6 (permalink)
Thanks. Point noted. The link is now there. Shocks? 300mm. I love them but might be going up to a 310. I'm kinda scared of the kickstand bracket scraping. I still have to lower the front so I'm about to, at least, try to sell them on the classifieds. I think maybe a Speedmaster might be better suited for these.
Bron-Yr-Aur Garage
Old 02-15-2012, 06:52 PM   #7 (permalink)
Sweet look Kreem, and a great step by step write up. It'll be a fine addition in the search function for others. My Lucas rig up is similar but very different. I hadn't even thought of those attachment points under the seat. I made two small right angle brackets, then bolted one side to the Lucas tail light using the two bolts that hold the Lucas interior reflector in place. The other side of the bracket then bolts the stocker turn signals in place, right and left.
I know everyone hates the stock signals, but I had them and as usual in a hurry.
That T100 has really inspired you! Congrats on a fine job!
LapinAgile is offline   Reply With Quote
Old 02-16-2012, 12:39 AM   #8 (permalink)
Haha thanks. Yeah, Triumphs have always appealed to me, but the new Bonnies have so many after-market parts, it's a tinkerer's paradise. Now I'm brainstorming ways to make it mine. I'm about to paint the fenders and am considering some coatings on the covers in the engine area. Also looking into powdercoating my rims, but I'm afraid to know the cost (de-chroming first, lacing the spokes, etc.) But it's fun anyways.
I'm not quite clear on your light setup. Post a pic? Might be something for another person to consider...
Ride safe
ksT100
Bron-Yr-Aur Garage
Old 02-16-2012, 03:16 AM   #9 (permalink)
Main Motorcycle: Thruxton
Gary_spain's Avatar
Other Motorcycle: Rieju Tango
Great post! Great pics! I have a Lucas rear light & a mudguard from a 2006 Bonnie in the garage and I've been meaning to chop it down and make a shortie-lucas rear end for my Thruxton - your post may be what I've been needing in way of a kick start!
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
Gary_spain is offline   Reply With Quote
Old 02-16-2012, 12:27 PM   #10 (permalink)
Main Motorcycle: 2010 Bonneville T100
Other Motorcycle: 2007 150cc Retro-scooter
It never occurred to me to trim the housing so it fits better, I may pull mine off and do that. Greatr work!
There is a fine line between "hobby", and "mental illness"
Owenbrau is offline   Reply With Quote
Rear turn signal relocate using BC front indicator bracket (with Lucas FEK) perfectbonnie Twins Talk 5 01-14-2011 03:32 PM
LED Lucas Tail light InkSlinger Twins Technical Talk 5 05-04-2010 09:18 AM
Lucas Tail Light Help Ma Junior Club Cafe' 17 11-05-2009 02:55 AM
Lucas Tail light? Ksound Hinckley Classic Triples 4 08-14-2008 02:10 AM
lucas tail light Freeze Club Cafe' 0 07-20-2006 12:47 PM
