Acewell - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 02-12-2012, 06:39 AM Thread Starter
Main Motorcycle: One that runs
Flatonr's Avatar
Acewell
I recently fitted an Acewell gauge on my 05 thruxton and it was a breeze to wire up. Now i'm trying to do it again with another Acewell on a 2011 Bonneville but this time it's proving to be quite a challange. Mainly because the wiring is very diffrent and I cannot seem to locate the proper diagram for the stock gauge cluster. I'd rather not have to spend hours with test lights figuring it out. Wondering if you might have any idea where a decent diagram for this model can be had? Thnx a ton.
Flatonr is offline
post #2 of 17 (permalink) Old 02-12-2012, 03:49 PM
DEcosse's Avatar
Not so easy - you have CANBUS gauges and there are no discreet speed & tach signals on that.
Otherwise
Purple - const power
Green/Red - Ign Power (careful - gree/red also turn signal)
White/Blue - hi beam
Green/Red - Lt Turn
Green/White - Rt Turn
Black/White - Neutral
Black/Yellow - Power Out to Speedo Sensor
Blacks are Ground
Red & Blue are the CANBUS signals
DEcosse is online now
post #3 of 17 (permalink) Old 02-12-2012, 05:02 PM
Main Motorcycle: '07 Black
Easy13's Avatar
Where can I get me some of those CANIBIS signals?
"Cognito Ergo Wrenchum"
Easy13 is offline
post #4 of 17 (permalink) Old 02-12-2012, 05:20 PM
Main Motorcycle: Two wheeled
Retro-Racer's Avatar
Other Motorcycle: several
Extra Motorcycle: next one
Heheh... beat me to the punch line.
/M
"With integrity, nothing else matters. Without integrity, nothing else matters."
Retro-Racer is offline
post #5 of 17 (permalink) Old 02-12-2012, 05:52 PM
DEcosse's Avatar
Caution - these may cause serious handling issues to your motorcycle.
post #6 of 17 (permalink) Old 02-12-2012, 06:24 PM
Main Motorcycle: Bonneville SE
PopPop's Avatar
And some serious fun, off of it.
Yes, I am as big a pain in the ass in person as I seem to be on line.
PopPop is online now
post #7 of 17 (permalink) Old 02-13-2012, 10:24 AM Thread Starter
Flatonr's Avatar
Spent a good part of the weekend playing with this. Got most of it wired up ok, signals, and other indicator lights no problem really. But I am having a few issues.
1st the Bonneville SE does not have a tach, I can wire directly up to the coil, but would assume there is a tach wire in the gauge cluster not being used that I can wire? or maybe not..
The other more serious problem is there seems to be a circuit in that stock speedo cluster that tells the ecu to fire or not to fire based on the test it runs when you first turn the key. Basically she will not fire at all with the Acewell hooked up. I have a feeling this may be related to the fuel pump or fuel level gauge which I have not been able to definitively identify. But have narrowed it down to the 5 wires in the picture. If I disconnected any of these, one at a time, she will not fire. Purple is power, black is ground, but what of the others, any idea what they are , and can any be by-passed or jumped to trigger the pump?
Flatonr is offline
post #8 of 17 (permalink) Old 02-13-2012, 01:24 PM
DEcosse's Avatar
The red & blue are the CANBUS signals - try terminating between them with 120 ohm resistor
post #9 of 17 (permalink) Old 02-13-2012, 08:45 PM Thread Starter
Flatonr's Avatar
Brilliant! will give that a go tomorrow. thank you.
Flatonr is offline
post #10 of 17 (permalink) Old 02-15-2012, 01:09 PM
DEcosse's Avatar
I can't guarantee that will work for you:
CANBUS requires a 120 ohm termination - in the first series of Speed Triple Keihin ECM's the resistor was all that was required; however in later models this does not work - presumably there is some active 'handshake' from the Instruments on those.
You can only try & see on yours as to whether it will work.
Note that features like the Fuel Level Sensor and MIL light are both carried on the CANBUS and not discrete signals, so you will lose those functions also
Good Luck!
Connecting Acewell Speedo & RPM meter on T140V DrMoon Classic, Vintage & Veteran 2 07-18-2009 10:10 AM
