My Bonny has lost power..... - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
SportbikeTrackGear
Old 02-11-2012, 04:46 PM   #1 (permalink)
Hope someone can help. Here's the lowdown.
2009 Bonneville T100. Staintune Exhausts, Arrow 2-2 Map, no other engine mods, original taco and speedo removed, using mini speedo now.
Yesterday, I swapped my bars to New Bonneville Super Bars. Since then, when I accelerate in any gear the revs go up, the exhaust sounds the same but the power doesn't come. The bike gathers speed but VERY slowly despite the noise the exhausts are making.
Before the bar change, everything else was running fine. I have no EFI light to know if it's a fuel injection issue so I thought I'd check here for ideas before going to the dealer.
Fuel is the same as I always use, 95 Octance unleaded. Can't think of anything else I've done recently to change it - actually I put a new battery in at the same time but can't see how that has any relevance.
The throttle isn't sticking - thought I might have done something to the cable when changing bars but again the engine seems to sound OK, just no power.......
Any thoughts?
HeezaGeeza is offline   Reply With Quote
Old 02-11-2012, 04:55 PM   #2 (permalink)
Main Motorcycle: Triumph Thruxton EFi
Other Motorcycle: Yamaha R1, Honda CB1000R
Clutch cable stretched not allowing it to engage?
GDCobra is offline   Reply With Quote
Old 02-11-2012, 06:34 PM   #3 (permalink)
Legend
Forchetto's Avatar
Yes, sounds like clutch slipping. Do you have any play or slack at the lever?.
Old 02-11-2012, 09:22 PM   #4 (permalink)
Main Motorcycle: 2006 Triumph T100
Other Motorcycle: 1968 Triumph T120
Hope it is just the clutch.
"Fuel is the same as I always use, 95 Octane unleaded."
No need whatsoever to run 95 octane in your bike.
2006 T-100, 1968 Bonnie.
BC Sleepers, No AI, 16" Parabellum Scout, western bars, Genmar risers, Progressive 412s, Michelins, Bonnie gel seat, AirHawk, Cortech Tri-bags, Go Cruise Throttle Control
Oldguy is offline   Reply With Quote
Old 02-12-2012, 01:01 AM   #5 (permalink)
We have a winner. No idea why but lost all play in the cable. Simple fix and back to normal now.
Thanks.
Old 02-12-2012, 01:03 AM   #6 (permalink)
The dealer told me not to run higher grade fuel in the Bonny, and specifically to avoid Shell V-max here in Australia as it doesn't do the engines any good.
Old 02-12-2012, 06:41 AM   #7 (permalink)
I don't see how it would do the engine any harm although the same would not be true of your wallet and I doubt you'd see any advantage from it.
Old 02-14-2012, 07:13 AM   #8 (permalink)
Main Motorcycle: Street Triple R 2009
bucksfizz's Avatar
Extra Motorcycle: I'd love a Thruxton
In Europe we use RON, and 95 octane is not particularly potent. The other measure is MON, and the US uses RON + MON / 2. Therefore, US fuels for public consumption tend to max out at 91 octane. This is what is probably causing the confusion. Standards - don't you just love 'em?
bucksfizz is online now   Reply With Quote
Bike had strange metallic sound while riding then lost power 666stars Triumph SuperSports 4 07-29-2011 09:30 AM
Scrambler lost power suddenly just now... Panic Reflex Twins Technical Talk 9 04-24-2011 04:11 PM
I think ive lost power? jbass Twins Talk 3 10-04-2008 02:29 PM
My 07 America "lost" power after accessory addition joelgcooper Maintenance & Workshop Talk 4 01-05-2008 10:12 AM
put a 18T on lost power!!!!!!!!!! ronniena Sprint Forum 9 12-20-2006 09:08 PM
