Renntec Engine Bars - Installation Notes - Very Interesting - Page 5 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com
Old 09-23-2012, 03:25 AM   #41 (permalink)
Ripper's Avatar
Originally Posted by broadwayron View Post
Yeah, I saw that too. New Bonneville said they would fit, though.
I had to send my Renntec bars back. Although they did indeed fit under the header pipes, the right hand bracket on the engine mount bolt would not clear the lower banjo bolt on the oil cooler. I managed to get the bars on, but took them off again because I was worried that the pressure and vibration from the bracket would crack the oil cooler.
I called Renntec and told them about this, and they claimed that Triumph keep changing the frame dimensions. However my bike is almost 3 years old. The problem could be easily fixed by Renntec by putting a notch in the right hand bracket to clear the banjo bolt, since it seems more likely to me that the real cause was heat distortion when the bars were welded, coupled with rather bad design in a tight area.
My engine cases are now protected by R&G Racing crash bobbins. They don't suit the bike as well as the Renntec bars looks wise, but are just as effective if not a bit stronger.
Ripper is offline   Reply With Quote
Old 09-23-2012, 08:20 AM   #42 (permalink)
Main Motorcycle: '10 Scrambler
Other Motorcycle: 10 Beta 520RR
Extra Motorcycle: 82 KE100
Interesting. I never would have thought about frame slider-type protection, since I'm worried about breaking stuff when I drop it in the dirt/sand. For those who haven't ridden in sand, yes, stuff breaks when you fall. I'm basically concerned about the extraneous parts, so I'm going to research those R&G "crash protectors", assuming the Renntec's are a no-go for sure. Thanks.
broadwayron is offline   Reply With Quote
Old 11-15-2012, 08:24 PM   #43 (permalink)
Main Motorcycle: 2012 HD CVO Convertible
I recently order the renntec crash bars for my 2012 T-100, do you think I will have fitting problems like Mr. Ripper had ?
Charles Lamb is offline   Reply With Quote
Old 11-15-2012, 11:01 PM   #44 (permalink)
Main Motorcycle: 2013 triumph bonneville
Originally Posted by Owenbrau View Post
Can't say enough good things about them. When I fell back in May, between them and my aluminum panniers I saved a lot of cosmetic damage. I got them after a garage drop cost me over $600, not including the scuffed engine covers I left alone. Falling in the rain, I only broke a turn signal lens.
any pics of your bike?
villageidiot327 is offline   Reply With Quote
Old 11-21-2012, 04:58 PM   #45 (permalink)
Main Motorcycle: 2010 Bonneville T100
Other Motorcycle: 2007 150cc Retro-scooter
Sorry I missed it, what view did you want to see?
There is a fine line between "hobby", and "mental illness"
Owenbrau is offline   Reply With Quote
Old 11-22-2012, 01:01 PM   #46 (permalink)
actually, i dug around a little and found some pics, i just wanted to see a pic of a bonneville with panniers.
i made panniers and racks for my past airhead bmw's, but decided to use seahorse cases and modded losi3030 racks on the bonneville
Old 11-22-2012, 09:48 PM   #47 (permalink)
Main Motorcycle: 2007 Thruxton Bonneville
Nickwiz's Avatar
Other Motorcycle: BSA Starfire 1968
Extra Motorcycle: 1930 Triumph NSD.
Heres some fitted to my old Thruxton. They work too
Be who you are and say what you feel because those who mind don't matter and those who matter don't mind......Dr Seuss
Nickwiz is offline   Reply With Quote
Old 01-14-2013, 01:47 PM   #48 (permalink)
Art
Thanks for posting prop and others, my Renntec engine bars arrived this morning, fitted this evening. My Bonne' is a 2010 EFI model and as mentioned in earlier posts I too found the fitting a little tricky due to:
1) The clearance between the bracket that attaches to the front engine mount and the oil union flange nut, I'd estimate there's about 6mm clearance after tightening, note I didn't use the spacers.
2) The limited space around the rear fixing nuts and bolts made things tricky too, I'd suggest the easiest configuration is to pass the bolt through from the left (clutch side) and have the nut on the right (stator side).
Took me about an hour. Tools used 19, 17 & 13 mm by ¼" & ½" square drive sockets, extension bars, ratchet handles & tee bars, 19mm combination spanner and a hammer and wooden drift to tease it all into place. Some pictures, excuse the mud we've been through some flooded roads and fords.
Oil union flange nut clearance, note I tightened the nut on the replacement engine bolt with a 19mm combination spanner as the socket wouldn't clear the bolts threads, I'll be cutting the bolt a little shorter some time soon.
Rear fixing bolts, I just managed to get on the lower bolt head with a 13mm ¼" drive socket on an extension bar.
Rear fixing nuts, plenty of room this side
Some overs - 6 off M8x20 bolts, 2 off M8 flat washers, 2 off M8x25 bolts and 2 off M12 spacers
Art is offline   Reply With Quote
Old 03-21-2013, 12:15 PM   #49 (permalink)
Main Motorcycle: t100 Bon Lucifer Orange
abie_baby's Avatar
Thanks for the pics Art. the advice on using the ratchet extension to help position the through-the-carb brace was good. Using the big spacer/washers will reduce that exposed thread on the engine mount bolt.
I needed a rubber mallet to get the position on the bars just right. Even with loose bolts, it is hard to shimmy into position.
I recommend a little inner tube scrap under the U-bolts that hold the bottom brace.
There may have been some of these in Prop's original pics.
I know the instructions call for fitting the bottom brace first, but I think getting that position right is much harder without seeing where the leftside bars will land. If I were doing it again, I would remove the OEM engine mount bolt and hang the ls bar for fit, which would have given me the precise location of the bottom bracket.
Love the wind
03 T100 Lucifer Orange and Silver
abie_baby is online now   Reply With Quote
Old 04-23-2013, 07:44 PM   #50 (permalink)
Main Motorcycle: Triumph Bonnie 2012
exlimeydedbt's Avatar
Nice! write up, but I cannot contact NB, need to know how much to ship to canada,sent 3 emails nada
exlimeydedbt is offline   Reply With Quote
Renntec Bars/engine mounting bolt Shadowsmurf Twins Technical Talk 17 02-12-2012 09:12 AM
Renntec engine bars on a T100 cool4cats Twins Talk 2 06-23-2011 05:51 PM
Renntec engine bars Acer64 Twins Talk 13 07-21-2010 12:31 AM
Renntec Engine Bars TheFixer Twins Technical Talk 7 08-09-2009 10:55 PM
Renntec Engine Bars gbuckham Twins Talk 2 11-02-2005 07:29 AM
