installing slip-on mufflers - is high-temp gasket sealant necessary? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 23 (permalink) Old 06-08-2011, 11:18 PM Thread Starter
Main Motorcycle: 2011 Speedmaster
Berms's Avatar
I noticed that the Dealer used some sort of white coloured gasket sealant when they installed my BC cocktail shaker mufflers on my speedmaster when I bought the bike new....
I have since taken the mufflers off myself and am in the process of re-installing them - is high-temp gasket sealant really necessary?? If so, what kind? The only one I could find at my local auto parts store was Permatex high-temp RTV RED gasket sealant....
Thanks for any advice. FWIW I've installed many exhausts on many different bikes over the years and never heard of or used gasket sealant before.
Cheers, Berms.
Berms is offline
post #2 of 23 (permalink) Old 06-08-2011, 11:35 PM
Main Motorcycle: Kawi Concours 14 '08
Other Motorcycle: Harley Dyna Custom '11
Extra Motorcycle: BMW R1150RT '04
The dealer probably used a hi heat silicone material. The permatex Hi heat copper colored material is what I used to seal up a set of Feked mufflers. Make sure you give what ever sealer you use time to cure before running it, or you may blow the sealer out of the joint, allowing black soot to collect at te joint. tomp
tomp is offline
post #3 of 23 (permalink) Old 06-09-2011, 04:11 AM
Main Motorcycle: '15 Ducati Hypermotard
'08 T100's Avatar
You are good to go with the red Permatex. Use it and let it cure overnight. There are lots of opinions here to the contrary about the necessity for it, but I say better to use it than put it all together and find that you have a leak.
'08 T100 is offline
post #4 of 23 (permalink) Old 06-09-2011, 05:02 AM
Forchetto's Avatar
Triumph specify a precise 4 cc of normal clear silicone sealant on each pipe-silencer joint.
Forchetto is offline
post #5 of 23 (permalink) Old 06-09-2011, 06:44 AM Thread Starter
Berms's Avatar
Thanks Forchetto.... I might as well do it just to be sure
Berms is offline
post #6 of 23 (permalink) Old 06-09-2011, 06:46 AM Thread Starter
Berms's Avatar
Hi, as well as the RED Permatex, I also found the Permatex "Ultra Copper RTV sealant" now I am confused as to which one to use??
Berms is offline
post #7 of 23 (permalink) Old 06-09-2011, 06:57 AM
Main Motorcycle: Trident 750
Black Dog's Avatar
Other Motorcycle: Yamaha XT660R
Extra Motorcycle: Yamaha XT600E
Since I have had the bike I have taken the silencers off half a dozen times. No sealant, no leaks. Mine seem to be a very good fit on the headers.
1994 Trident 750 (the rolling project)
2006 Yamaha XT660R (the daily ride)
1995 Yamaha XT600E (the resto project)
2002 Sprint ST 955i, 2005 Bonneville (now sold)
www.goingfastgettingnowhere.blogspot.com
Black Dog is offline
post #8 of 23 (permalink) Old 06-09-2011, 07:14 AM
Main Motorcycle: Bonneville, of course.
Apdingfield's Avatar
Other Motorcycle: 1975 Yamaha DT400
My cheap reverse cone shorties leaked like a sieve before I added a sealant. The BC pipes that you have are no doubt much higher quality, so it may not be an issue, but it couldn't hurt to run a small bead of high temp sealant in there.
Apdingfield is offline
post #9 of 23 (permalink) Old 06-09-2011, 08:40 AM Thread Starter
Berms's Avatar
This might sound like a really dumb question, but exactly how do you apply the stuff??? Do you just run a bead around the end of the header pipe before you slip the muffler on? Or do you slip the muffler on first and then apply the sealant at the join?
Berms is offline
post #10 of 23 (permalink) Old 06-09-2011, 08:47 AM
Main Motorcycle: America
just run a thick bead around the header pipe, then use your finger to smear it to about 1 to 1 1/2 inches wide. You don't need so much that when you put the muffler on it oozes out all over the place. Just wipe it off your hand with a rag as soon as you are done smearing and it will come off easily.
Firebird is offline
gasket sealant or not ??? catchalot Vintage Technical Tips & Tricks 26 12-15-2012 03:59 PM
Gasket sealant or not? Vince C Classic, Vintage & Veteran 10 08-20-2009 09:36 PM
Underseat tray? Type of gasket sealant for sump gasket? ladyhawk Daytona Deliberations 0 09-11-2008 06:30 AM
Installing TBR Slip On granburysprint Sprint Forum 16 05-01-2008 09:04 AM
gasket sealant for Tbike pipes? dazco Twins Talk 4 09-06-2005 11:58 PM
