New Spec Triumph Bonneville Cam Cover Gasket - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-06-2011, 03:07 PM   #1 (permalink)
Main Motorcycle: 2010 Bonnie
Other Motorcycle: Fastest xv250 in NorCal
So I had my 2010 Bonnie go through a warranty fix for a weeping cam cover gasket. The new gasket the dealer installed looked slightly different than the original one that was on my bike. The new gasket (#T1260904) has a lip that cups around the outside of the cylinder head and appears to be made of a softer material than the previous gasket. Since I didn't do the install, I couldn't see if there is any difference on the inside of the gasket. Hope this new gasket would improve the oil sealing properties of the Bonnie cam cover.
HkmadeCCC is offline   Reply With Quote
Old 05-06-2011, 03:15 PM   #2 (permalink)
Legend
Forchetto's Avatar
Thanks for that. It now looks as if both components responsible for the tiresome leaks reported from the cam cover have been updated and presumably improved.
These are the items to look out for if you are plagued by leaks:
The Sealing washer T1260337 rather than the old T1260309.
The Cam cover gasket T1260904 rather than the old T1260900
Forchetto is online now   Reply With Quote
Old 05-06-2011, 03:39 PM   #3 (permalink)
Thanks for the follow-up Forchetto! Guess Triumph finally figured out that it's more economical to redesign the gasket than to keep reimbursing dealers for warranty fixes. Probably didn't do well for their company image either
Old 05-06-2011, 05:23 PM   #4 (permalink)
Main Motorcycle: bonneville t100
keithk's Avatar
am i to take it that the new washers and gasket will work with older bonnies? specifically, am 08 t100?
2008 Bonneville T100: A.I. Removed, Bellacorse Air Removal Kit, Nology ProCoil, NGK Iridium IX, Epco Low Pipes, Ikon Springs, Ikon 7610 Shocks, Superbars, Mains:140's, Pilots:42's, Thruxton needle , 2 turns out
keithk is offline   Reply With Quote
Old 05-06-2011, 06:09 PM   #5 (permalink)
Legend
Forchetto's Avatar
Yes. It doesn't look as if any of the relevant castings have been changed.
Old 05-07-2011, 04:08 PM   #6 (permalink)
keithk's Avatar
cool. that is good news. i have ignored my pesky cam cover leak for quite awhile, but was recently thinking about biting the bullet and getting it fixed. nice to know that triumph has finally got off their butt and fixed the cam cover gasket problem. -keith
Old 05-08-2011, 04:18 AM   #7 (permalink)
Askari's Avatar
Clever
Have to give it to triumph fix a problem? without ever admitting liability fo a problem. To be fair i suppose they are no different from any other producer of goods. It wasnt going to kill anyone except a dealer maybe
Askari is offline   Reply With Quote
Old 05-08-2011, 10:03 PM   #8 (permalink)
El Moderatore
Main Motorcycle: 2007 Bonneville LeMans
Calliway's Avatar
Other Motorcycle: 1972 CB350
Extra Motorcycle: 1977 GS400
I wonder how long that has been. I changed mine 2 years ago and it has an outside lip.....
Calliway is offline   Reply With Quote
Old 05-09-2011, 01:24 PM   #9 (permalink)
Main Motorcycle: '08 Bonnieville Black
04200brick's Avatar
Does anyone know if there is a service bulletin on this, or is it just a warranty fix -- if your bike is still under warranty?
Motorcycle for happy life.
04200brick is offline   Reply With Quote
Old 05-09-2011, 01:42 PM   #10 (permalink)
Legend
Forchetto's Avatar
All this is just conjecture at the moment. Data gathered as we go along.
I would imagine the dealers will get a Service bulletin or at least a web address where they can check to see if the bike they're about to service is subject to any changes.
Wouldn't it be nice if someone in the know from the factory was seconded here for a few hours each month to answer all sorts of questions, eh?.
Forums such as this do a lot for them, sales, loyalty, etc and we can't even share an out of date electronic file of a service manual that has been superceded by a new edition... Pathetic.
And yet you can go to project www.gutenberg.org and download War and Peace for free for your Kindle electronic book.
Cam Cover gasket killian101 Twins Technical Talk 23 05-13-2010 12:12 PM
D600 cam cover gasket nick325i Triumph SuperSports 2 03-08-2007 11:20 PM
Triumph Bonneville T140 (US Spec 1978) salsa-king Classic, Vintage & Veteran 5 05-14-2006 08:57 AM
