New Spec Triumph Bonneville Cam Cover Gasket - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-14-2012, 04:45 AM   #21 (permalink)
Main Motorcycle: Bonnie T100 of course
Other Motorcycle: I wish
Extra Motorcycle: Yes please
Originally Posted by Bonnie1000th View Post
The old style cam cover, cam cover gasket and cam cover seals are use up to engine number 456551 for the entire classic model lineup.(2001-2009).
The new cam cover, cam cover gasket and cam cover seals goes from engine number 456552 for the entire classic model line up( 2009 to present).
It seems they've changed the bolts in addition to the Cam cover, seals & gasket:-
http://www.worldoftriumph.com/triump...lock_03=610610
Bonneville & SE EFI > Eng No 456551
SPARES KIT CAM COVER BLACK Triumph Motorcycle Part Number T1260912
BOLT, SHLD, TX, M6X24.95, SLV Triumph Motorcycle Part Number: T3332052
SEAL,CAM COVER Triumph Motorcycle Part Number: T1260309
SEAL.CAM COVER Triumph Motorcycle Part Number: T1260900
Bonneville & SE EFI Eng No 456552 >
COVER CAM CRKL BLACK LINISHED Triumph Motorcycle Part Number T1261923
BOLT, SHLD, TX, M6X24.95, SLV Triumph Motorcycle Part Number: T3332051
SEAL CAM COVER SCREW Triumph Motorcycle Part Number T1260337
SEAL CAM COVER Triumph Motorcycle Part Number T1263333
Interestingly, being ignorant of the cam cover and bolt changes, I've used the new gasket & seals on my 2008 T100 without any problem whatsoever so the changes to those items must be very subtle.
Aussie_T100 is offline   Reply With Quote
Cam Cover gasket killian101 Twins Technical Talk 23 05-13-2010 12:12 PM
D600 cam cover gasket nick325i Triumph SuperSports 2 03-08-2007 11:20 PM
Triumph Bonneville T140 (US Spec 1978) salsa-king Classic, Vintage & Veteran 5 05-14-2006 08:57 AM
