OBERON Touring footpegs for Bonneville SE
21K views 14 replies 9 participants last post by  Point37
#1 · (Edited)
I find two things wrong with the OEM footpegs on my SE: They're a little too far forward, even for my smallish feet. I've read about swapping the left and right pegs around but I'm not keen on this for the second reason: They're so large that I find that when manouvering the bike I keep hitting them with my shins.
Another minor annoyance is that the rubber tends to sort of grab my boots and/or trousers because of its "stickiness" if you like. The friction between them and your rubber-soled boots makes moving the feet about difficult. I don't recall having this trouble with Jap bikes, maybe it has something to do with the rubber compound on them being a bit more "plasticky" and slippery.
I needed to try some smaller and slimmer pegs.
I've just bought a set of OBERON Touring pegs, part number for the Bonneville: FPT-0025. Price £38 the set ($62, €44).
There are other models and lots of different colours on their site. Mine are boring silver anodised, but there are plenty of colours to choose from. The photo below shows the range. The first ones are called "Racing", the second "Studded" and the last ones are the "Touring" model:
I've bought them directly from the maker rather than through a reseller because I've read of several cases where ignorant resellers have supplied the wrong adaptors and the pegs just droop badly. This is due to them confusing the pegs for the Thruxton and for the Bonneville. They're not the same.
The correct pegs have a sort of "suplement" in the form of some pegs pressed-in or, like mine, an additional block of alloy screwed very securely into the adaptor.
I would like to say that things went perfectly but, of course, with
after-market goodies they rarely do. A couple of problems:
* The pegs themselves are beautifully-made and well finished, but, the forked end is 3 mm narrower than the OEM items which means they flop about and rattle abominably once fitted. I suplemented them with a couple of large M10 washers to "pad" or "shim" out the space. This is essential to provide precision of operation.
* The OEM circlips or spring clips that hold the pivot pins are utter crap. They appear to be hardened, but not tempered. This makes them extremely brittle and one of them simply shattered in three pieces when being re-fitted. Good job I had some decent quality spares... Get yourself some just in case. The dimensions of the pin are in the photo. You can tell the tempered sort because they're a sort of gunmetal colour. Notice the Triumph ones are a bright finish.
The new pegs sit an inch or so further back and provide a more comfortable position for my legs. There are no limit "feelers" on them though, and being an inch narrower as well you could overdo it when cornering, so watch out you knee draggers...I'm going to look into drilling and tapping these to see if the stock pegs "feelers" can be adapted.
Triumph make two lengths of feelers: One for stock bikes, and longer ones that are supplied with the accessory centre stands. Perhaps the longer ones will be better being as these new pegs are quite a bit shorter.
For the Speed/power freaks out there: they're 100 grams lighter each: 0.2 Kgs saved there...
#2 ·
I fitted oberons and have the studded ones. I didn't have any difficulty fitting them or need to change washers etc.
Maybe its because they are a different length, model etc.
These where one of the first mods I did as I kept hitting my calves on the origional ones. I wouldn't change them at all one of the best things I did. I'm only a size 6, euro 39 shoe though and these fit great.
#3 ·
Forchetto, did you notice that the supplied screws to attach the peg to the adapter seem to be shorter than they could be? Especially considering each screw is the only thing holding the foot peg.
I bought these pegs some time ago but never installed them, lost interest when I saw how much shorter and farther back they are than the standard pegs--I have size 10½ (44) feet. The Oberons do look good, though.
#5 ·
Yes, I bought some 20mm screws for them too, still haven't installed them. I might try them sometime, a bit more blue bling for the blue bike.
#6 ·
Well, i got the studded Oberon's around this time last year...after i had dropped the Thruxton doing a U turn and the brake side footrest snapped.
I didn't want to replace it with another stock one, because they seemed to be made of Monkey metal, cast alloy that was prone to break to easily, plus i agree with Forchetto, the rubbers were a bit too "sticky" and i found they stopped me moving my feet around.
They also suit the Thruxton, with the footrests being slightly further back than on the other twins.
G ; )
#7 ·
Quick question here. I posted a similar question in the Cafe Racer forum. Are the Thruxton pegs further back than the Bonneville? Or just higher? I'd like a Thruxton, but I am afraid the knee bend will kill me. I'd like them lower and similar to where they are on the Bonneville. Is that possible?
#10 ·
Not tried but it's likely, at least on standard Bonnies, after all some folk have used a passenger peg for the rider in emergencies.
Breakages on Thuxtons and Scramblers are not reported, that's because the clevis part of the peg supports are built in one piece with the outrigger support brackets, unlike the Bonnie which has a separate, bolt-on clevis.
#14 ·
Fitted oberon touring footpegs to my 2007 Bonneville t100 ,which are ok in themselves so far ,but the foot controls are now badly positioned in relation to the footpegs. A shorter gear change lever is required-(I tried a cheap Honda xr150 gear lever from hong kong which I had shortened by 24mm,but the flat bar type lever is only 10mm thick and can wiggle from side to side on the gearbox shaft.) the rear brake pedal is also now badly positioned in relation to footpeg. It is becoming an expensive problem to solve. I am wishing I had just put up with the standard set up of footpegs and controls. Any comments would be appreciated. regards,Enrico
