Ridiculously easy AI disabling - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-21-2011, 09:07 PM   #1 (permalink)
Main Motorcycle: 1960 Anniversary T100
Burphel's Avatar
Other Motorcycle: '79 KE250B (project)
Ok, I've been mucking around on this forum for the better part of a year now and had my Bonnie for about 9 months. I've seen a lot about removing the Air Injection system and always figured I'd do it eventually. This weekend I finally got in a kit and set up TuneECU and did it.
Only to discover that I could have gotten the same performance results free and in about 2 minutes. Granted, this method isn't going to remove the pound or so of junk or clean up the look of your engine, but it absolutely will take care of the whole popping on deceleration thing along with accelerated pipe bluing. This follows the whole "stick a marble in the tube" concept, but most of the people who've done that imply altering the tubes between the cylinder head and the valve, which is a cramped space and has some pretty beefy connectors involved.
What you'll need:
1) A zip tie or two.
2) Something to plug an ~15mm hole or a marble/ball bearing to plug a ~10mm rubber hose.
3) The allen wrench to take off your seat.
Instructions:
1) Remove the seat.
2) Yank this tube out of your airbox.
3a) Plug the hole in the airbox with something. A rubber stopper of the appropriate size should work, or even tape over it.
3b) If you *really* want to look unaltered, you could shove a marble or ball bearing into the hose and plug it back into the airbox instead (if you do this, skip step 4).
4) Zip tie a kink in the tubing and shove it up under the gas tank. Be careful where you put it as the throttle cable/levers are in between the carbs/throttle bodies and you don't want to impede the movement there. If you think this might be a long-term solution, it'd be worthwhile to use another zip tie to secure the hose to your wiring harness or something else out of the way.
5) Put the seat back on and go for a test drive.
That's it. It's that easy. No worries about the engine light since the solenoid is still hooked up. No hardware to replace. Don't even need any tools other than maybe an allen wrench to get the seat off. If you're like most of us here, you'll probably want to eventually do a proper removal. But this method gets you the major benefits of an AI removal for the cost of two bits of junk you've probably got laying around the house and the hardest part is probably removing the seat.
Enjoy.
Averaging 50 miles per "What year is that?"
Burphel is offline   Reply With Quote
Old 02-22-2011, 04:59 AM   #2 (permalink)
Legend
Forchetto's Avatar
Good idea, beats my suggestion of stuffing marbles up the injector hoses...
Old 02-22-2011, 06:24 AM   #3 (permalink)
Main Motorcycle: Triumph Scrambler
Will the same procedure work on a carbed Scrambler?
stein is offline   Reply With Quote
Old 02-22-2011, 07:36 AM   #4 (permalink)
Legend
Forchetto's Avatar
Yes. The AI system is basically the same.
Old 02-22-2011, 11:38 AM   #5 (permalink)
Burphel's Avatar
Another plus to this setup would be if you live somewhere that does environmental inspections (provided it's a scheduled thing, not a suprise). Right before you go in to get smogged, pull the plug, cut the ziptie, stuff the hose back in the airbox, and you're in bunnyhugger mode. As soon as you're done, it's back to being AIless.
Old 02-22-2011, 01:15 PM   #6 (permalink)
Main Motorcycle: T100
lewilewi's Avatar
Other Motorcycle: Fazer
Ha you say its free !
You need to buy a ziptie
o yeh nice idear .
lewilewi is offline   Reply With Quote
Old 02-22-2011, 01:40 PM   #7 (permalink)
Burphel's Avatar
If you don't have a zip tie and piece of duct tape somewhere in your home, you need to tear up your man card.
Old 02-22-2011, 02:27 PM   #8 (permalink)
lewilewi's Avatar
Old 02-22-2011, 03:54 PM   #9 (permalink)
Main Motorcycle: 2000 ZRX1100
Other Motorcycle: 10' Bonneville
Extra Motorcycle: 81' Sachs Sundancer
Can same technique be used on EFI?
EDIT-Didnt see TuneECU on there, guessing this works just fine.
vinnie9000 is offline   Reply With Quote
Old 02-22-2011, 05:30 PM   #10 (permalink)
Legend
Forchetto's Avatar
Note that it isn't enough to just turn off the AI with TuneECU. This only disables the MIL light. You must, at least, block the hose as well otherwise the system still injects air into the exhaust.
Unplugging the solenoid is even worse. Once this is done the valve is open 100% of the time instead of when idling, deceleration and warming up like at present.
Easy AI disabling Forchetto Twins Technical Talk 21 01-18-2011 02:44 PM
AI disabling, not removal? perfectbonnie Twins Technical Talk 4 01-18-2011 06:42 AM
Disabling the oxygen sensor q2quest ECM and FI Tuning - Help, Tips & Tricks 8 09-16-2010 02:55 AM
disabling alarm? bgjb2005 Triumph SuperSports 5 01-02-2009 10:30 PM
Is a new tune required after disabling the SAI? JTXR Sprint Forum 1 09-17-2007 06:03 PM
