09-01-2010, 10:16 PM
Formula Extreme Main Motorcycle: 2012 Ducati SF848
Posts: 438 Other Motorcycle: 2011 Daytona 675R
Handlebar Size Question
About 3 months after purchasing my 2010 Bonneville SE, I had a chance to sit on a 2010 Thrux. I really like the riding position with the Thrux handlebars (and rearsets, but that's a different issue all-together). Does anyone know if the 2010 Thrux bars are 7/8" like the SE? I can't seem to find the info anywhere. Assuming that I won't need risers, I thought it might make for a nice like for like swap and give me a more comfortable riding position. Thoughts?
~Ex
2010 Triumph Bonneville SE - RIP (7/9/11)
2011 Triumph Daytona 675R
2012 Ducati StreetFighter 848
09-02-2010, 04:00 AM
World SuperBike Main Motorcycle: 05 T100
Posts: 2,232 Other Motorcycle: Don't need another one!
I believe the Thruxton bars changed to 1" when they dropped the clip ons for "normal" bars. You should be able to get some similar ones in 7/8" from one of the usual aftermarket sources. I have 1" LSL sport tourer bars on my T100 which are a little higher than the Thruxton bars, but a lot lower than the stock ones. It puts a bit more weight on your wrists when going slowly but you don't get that feeling of acting like a sail at high speed.
Paul.
Herts. UK
09-02-2010, 03:54 PM
That is correct, the current Thruxton with handlebars has 1" bars. Norman Hyde makes a similar bar in 7/8" called "M" bars to fit earlier Thruxtons. To fit handlebars you will need to change your top yoke to one that will accept risers. Norman Hyde, LSL, Bellacorse, newthruxton.com, South Bay Triumph and others carry various top yoke conversion kits.
Edit - heck I just reread the original post - you have a Bonneville! The SE has 7/8 bars? I thought all bonnies were 1-inchers.
Reason: correction and addition
09-02-2010, 05:17 PM
The newer Bonnies with mag wheels and the separate brake fluid reservoir have 7/8" bars (as does the Scrambler). The T100 (and now the Thrux) still has 1" bars. God knows why Triumph doesn't standardise on one or the other.
Paul.
Herts. UK
09-04-2010, 07:57 PM
Thanks PAAS. I'll look into an aftermarket set. Perhaps the 22mm Rizoma bars would work....
~Ex
12-13-2012, 01:50 AM
Production 125 Main Motorcycle: Triumph Bonneville
Switching to Thruxton Bars
I was also looking into switching from my stock bars on my '11 bonneville base and went into my local triumph place and asked about the Thruxton bars. They were saying that there was going to be a couple of hours to do it with all the cable changes and such but I assumed that there was adequate cable that I could just take off the controls and the grips, unscrew the bars from the clamp and put the new ones on and screw the controls on the new bars and slip the grips back on as well. I feel like they're not being honest with me as it really doesn't seem like it should take more than 1/2 hour at most. Are the Thruxton bars really that difficult that it would take that long and if so, are there similar bars I can get that a direct transfer without recabline is possible. I'd like to find some Cafe bars that I can just switch the controls and grips with.
The video where I got this idea is
12-13-2012, 06:27 AM
As stated in the posts above, the issue(s) with fitting the 1" diameter bars used on the current Thruxton to your 2011 Bonneville that has 7/8" bars is the difference in diameter. I.e. the handlebar clamp, switchgear, throttle tube, grips, brake and clutch levers on your bike are designed to fit to a bar of 7/8" diameter and you are going to try and fit them to a 1" bar. That's the problem, not the cables. It's not impossible (not much is), but I'm not sure your dealer has thought it through and it would be much easier to fit another pair of 7/8" bars. There's a "sticky" post at the top of this sub-forum's home page with loads of info about the different bars available - http://www.triumphrat.net/twins-tech...ar-thread.html
Paul.
Herts. UK
12-13-2012, 11:30 AM
Site Supporter Powerbike Main Motorcycle: 2012 Bonneville Mag Wheel
Everyone has provided you the sizing information you need... FWIW, I went through (5) pairs of bars before settling on Rizoma's with Rizoma risers and grips. I don't think the Rizoma's are going to give you the "Thruxton feeling" you are looking for. That being said, I love mine. If you truly want what the Thruxton offers without swapping out the risers, then the M-bars are for you. Hope this helps.
12-14-2012, 11:38 AM
Powerbike Main Motorcycle: 2009 Thruxton
http://m.youtube.com/watch?v=lcutlc7BBHE
The dealer is giving you BS - I'm pretty sure you will not need to change cables or the brake line going to Thruxton bars on your Bonnie - they are lower and narrower. It should be a very simple job.
12-14-2012, 07:35 PM
No it won't, because of the reasons given in my post two above yours.
Paul.
Herts. UK
