Valve cover gasket oil leak repair or replace? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 53 (permalink) Old 08-30-2010, 12:32 PM Thread Starter
nagibe's Avatar
Hi everyone. I have a small oil leak so I took it to the mechanic he told me it was the valve cover gasket but he would try to clean it and use some kind of sealant first to see if that works. Should I just go ahead and replace the damage part or repair it? Just in case I need to place an order online where can I get a valve cover gasket bike bandit newbonneville?
nagibe is offline
post #2 of 53 (permalink) Old 08-30-2010, 01:03 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
baxter will have them in stock.You might try replaceing the 4 rubber seals on the v/c bolts first ,they are what tightens the cover down the bolts bottom out on the head,alot of times there all thats bad .Replace them even if you want to put a new gasket on.A trick that will help alot if you replace the gasket ,get some weather strip glue and glue the gasket to the cover,will make it a much easyer job.
mikeinva is online now
post #3 of 53 (permalink) Old 08-30-2010, 01:09 PM
Main Motorcycle: '07 Bonnie Black
Sic Semper Tyrannis's Avatar
Other Motorcycle: '68 Bonneville T120R
Extra Motorcycle: '83 Honda Interceptor
This is a fairly common problem. My 07 bonny (31k) developed a bit of a seep a while back. I did my second valve clearance check this weekend and applied some clear RTV to the gasket when I put the cover back on. I put on a very thin bead and then smeared that flat to remove any excess. So it was a very thin sheen of liquid gasket. No seeping thus far and I ride pretty hard.
Unless the gasket has a crack or some other deficiency the liquid gasket should suffice. And if it doesn't just order a new gasket.
Cheers.
Veho ergo sum!! '07 Bonnie Black, D&D reverse cones, no AI, airbox removed, UNI Pods, 140 main, 42 pilot, down-turned m-bars, LSL rearsets, progressive springs.
Sic Semper Tyrannis is offline
post #4 of 53 (permalink) Old 08-30-2010, 02:21 PM
Main Motorcycle: 2013 Triumph Scrambler
Other Motorcycle: 2013 KTM 500 EXC
I too had a leak from the cam cover. I ordered a new gasket and the gaskets/bushings for the 4 cover bolts through bike bandit. They have exploded views of all components to help oder the exact parts you need....The actual work was pretty easy to do...I did not use any sealant and havent had any new leaks in about 1000 miles of riding pretty hard...
hbmichael is offline
post #5 of 53 (permalink) Old 08-30-2010, 03:53 PM
Main Motorcycle: 2010 Speedmaster
Hyates's Avatar
My 2010 Speedmaster with 7,000 km (4500 miles) has just started to weep around the right side sparkplug, and in one spot started to run down into the spark plug well.
I checked the four bolts that secure the valve cover, and they were tight. I did torque them to 14 Nm anyway. If it still weeps/leaks, I'll have the dealer fix on warranty.
This seems to be a very common/weak design on this engine. A shame for an otherwise beautiful piece of engineering.
H.
2010 Speedmaster Black w/ New England White. AI Removed. TTP Breathe, TTP O2 Sensor Kit, TTP Tune 2, DNA Air Filter, Trident Exhaust (toned down w/ Acousta-fil and custom unvented earplugs).
Hyates is offline
post #6 of 53 (permalink) Old 08-30-2010, 03:57 PM
Forum Liaison
Main Motorcycle: XT1200Z
BlackTigNYC's Avatar
Other Motorcycle: Duc?
most likely nothing wrong at all with your gasket.
I had a really bad leak all around my cam cover. What I did was simply buy another set of of rubber cam cover screw washers, drop them right on top of the old ones and retorque the screws down to 14NM. Didn't even take the cover off. Guess how much cam cover oil drip I have now.... ZERO. I did that thousands of miles ago.
BlackTigNYC is offline
post #7 of 53 (permalink) Old 08-30-2010, 04:05 PM
Hyates's Avatar
Yeah, I concur. I think the gasket is fine. It's neatly seated. I checked all around the valve cover, and the gasket is uniformly placed.
However, since it's on warranty, I don't want to double stack washers on it. I'll let the dealer figure it out.
My wife's '07 Speedmaster (which was new in Oct/09 as a left over) is also starting to develop 'moisture' around the spark plug wells. It's not leaking yet... give it time
H.
Hyates is offline
post #8 of 53 (permalink) Old 08-31-2010, 03:45 AM Thread Starter
nagibe's Avatar
as always great advice from everyone. thanks a lot.
nagibe is offline
post #9 of 53 (permalink) Old 09-09-2010, 01:18 PM Thread Starter
nagibe's Avatar
update
The mechanic applied the liquid gasket or sealant and told me that it should stop the leak it didn't. I just noticed a small leak last night in the same area. When I picked up the bike with him last week he told me to bring it back again if it leaks and he would redo the work for free I'm about to place an order with bikebandit for a new valve cover gasket and the 4 rubber seals.
nagibe is offline
post #10 of 53 (permalink) Old 09-11-2010, 05:37 PM
Hyates's Avatar
Torquing worked...
For my 2010 that was starting to weep/leak, I torqued the cam cover bolts to 14 Nm. The bolts seemed tight already, but figured I'd torque them up since I already had the tank off.
Did a 600 km (400 miles) spin a couple days ago at highway speeds, with some high revs on one of my favourite curvy/hilly roads. No leaks or weeps. The engine worked pretty hard on some good grades on my run, so I'm keeping my fingers crossed. I have 7900 km (4900 miles) on the bike now.
I will be ordering spare rubber seals for spares.
H.
Hyates is offline
'00 Clutch cover gasket - hard to replace? scritch Sprint Forum 1 02-24-2010 08:00 PM
leak at valve cover gasket? dogeddie Twins Technical Talk 8 04-05-2009 11:36 PM
New R3 Valve Cover Gasket Leak & Timing Chain Noise JAYB007 The Rocket Science Forum 3 12-04-2008 09:04 PM
Eay to replace the cam cover gasket? Tenover Twins Technical Talk 14 11-01-2007 06:20 PM
valve cover gasket leak Grigsby Twins Technical Talk 12 09-30-2006 06:58 PM
