do rotors and sprocket need to be on the wheel to balance? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 16 (permalink) Old 05-14-2010, 09:06 AM Thread Starter
Main Motorcycle: thruxton
Other Motorcycle: colnago
Extra Motorcycle: surly
that sums it up... do i need to put the rotors and the sprocket back on my wheels before they get balanced, or are they close enough to the center that it wont matter?
bred is offline
post #2 of 16 (permalink) Old 05-14-2010, 09:42 AM
I don't know the official answer, but I know that both of my wheels have been balanced with rotors and sprocket attached.
Marty
Baltobonneville is offline
post #3 of 16 (permalink) Old 05-14-2010, 11:42 AM
Modolicious Moderator
Main Motorcycle: 2004 Speedmaster
marc hanna's Avatar
Ideally yes. But the sprocket might not stay on during balancing on account of it not actually being fastened to the rim.
UNI pods, AI removed, de-baffled TORs, relocated battery, custom bobbed fender, custom wiring, etc
marc hanna is offline
post #4 of 16 (permalink) Old 05-14-2010, 11:44 AM
Main Motorcycle: '07 Thruxton
hobbes80's Avatar
Other Motorcycle: None, ATM
I would imagine the answer is yes, they would need to be on there. Anything that could potentially change the way the wheel is balanced before it goes on the bike should be on the wheel when it is balanced so that it is taken into account.
if the sprocket or rotor is not perfectly balanced, then when you mount them it will throw the balance of the wheel off as well. It makes sense to have it all put together and balance it as a single unit.
Whether or not this is the "right" way by the manual I couldn't tell you, but if my mechanic balanced my tire without the rotor or sprocket, I'd make him rebalance it to make sure it is still correct.
Then what IS it fastened to? (I consider the hub to be part of the rim)
"...of course, he was the walrus. I could be the walrus, but I'd still need to bum rides off of people"
hobbes80 is offline
post #5 of 16 (permalink) Old 05-14-2010, 11:53 AM
marc hanna's Avatar
It just sits in place. The cush usually provides just enough grip so that it doesn't fall out when you remove the rear wheel, but if you jar it a little, it will fall right out. It's the axle and swing arm that hold it in place when on the bike.
post #6 of 16 (permalink) Old 05-14-2010, 12:18 PM Thread Starter
on the thruxton, the sprocket bolts to the hub, as does the disk/rotor.
bred is offline
post #7 of 16 (permalink) Old 05-14-2010, 12:26 PM
marc hanna's Avatar
So the Thruxton doesn't have a cush drive?
post #8 of 16 (permalink) Old 05-14-2010, 12:31 PM
marc hanna's Avatar
Actually, just looking around some other threads, and it appears the Thruxton does have a cush drive. There is an aluminum hub that the sprocket bolts to, but that hub is not bolted to the rim's hub - there's a rubber fitting that separates the two. Give it a try: next time you have your wheel off, just pull on the sprocket, it will slide right out.
post #9 of 16 (permalink) Old 05-14-2010, 12:50 PM
Main Motorcycle: Can't decide now!!
Ventura's Avatar
Other Motorcycle: Scram + Thrux
Extra Motorcycle: '71 BSA Thunderbolt
The Thrux is just the same as the other variants.
Sprocket bolts to this part of the hub...............
Which connects to the remainder thro the cush drive................
V.
2006 Scrambler, VARK'd, FCR39's & DNA's, 790 In-cam, Pieman'd igniter, Zard 2:1.
2005 Thruxton Black, with ARK, FCR 39's & Uni's, Retimed 790 cams, Barnett clutch and suchlike!!
Ventura is offline
post #10 of 16 (permalink) Old 05-14-2010, 12:59 PM Thread Starter
well, i considered the cush hub as part of the main hub assembly. its in there pretty well...
regardless, does the disk have to be on? ive read balancing instructions, on real balancing equipment, not the homemade ones, that disks and sprockets should be removed... but it just seems counter intuitive...
bred is offline
Spoke wheel balance - heavy spot Snakeoil Classic, Vintage & Veteran 4 02-01-2010 12:08 PM
Rear Wheel balance Rich_Williams Speed Triple Forum 4 04-07-2008 11:04 PM
Wheel balance without tire airrider03 Sprint Forum 15 05-01-2007 06:25 PM
Rotors/sprocket? T3 Sport / Touring Forum 2 11-04-2006 03:22 PM
Rear wheel balance adapter? AlaskaSprint Sprint Forum 2 08-06-2006 02:15 PM
