Rotella Synthetic T6 oil - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 20 (permalink) Old 05-07-2010, 10:22 PM Thread Starter
Main Motorcycle: '07 Truxton
jlearman's Avatar
I've read the threads out there praising the shell rotella synthetic oil, so I went to pep boys to get a gallon of it for my 2007 thruxton. However, I'm not sure if what I bought will work. It's called Rotella T6 Full Synthetic 5w-40. It looks like it's build for 18 wheelers or something. I did put it in my bike, but I only have a 1 mile on the engine with this oil in it. Since I know nothing about oil specs, I was hoping someone out there could tell me if this will be good for my engine, or if I've made a terrible mistake.
Here's a link to the description:
http://www.shell.com/home/Framework?...t6_detail.html
jlearman is offline
post #2 of 20 (permalink) Old 05-07-2010, 10:35 PM
nofate's Avatar
Rotella T6 oil carries the JASO - MA rating so it will be fine. I intend to use it for my next oil change.
Happy trails,
Rick, 2010 Scrambler 900
Flying with Rick Video at: http://www.youtube.com/watch?v=g6my0FM9F_Q
nofate is offline
post #3 of 20 (permalink) Old 05-08-2010, 12:10 AM
Main Motorcycle: None! :-(
Motul 5100 for me.
97TB is offline
post #4 of 20 (permalink) Old 05-08-2010, 12:36 AM
Main Motorcycle: '03 T-100 & '08Tiger1050
Rotella is a diesel oil, and yes, it does have the JASO MA rating. If it were a Hardley, it would probably be just fine--similar rpm's with the big diesel rigs. I wouldn't even consider this oil because of the rpm's I run my bike, and because of the viscosity rating. The manufacturer specs the oil viscosities that are acceptable as 15W50, and 10W40. The Rotella you mention meets neither spec.
I just put a gallon of Rotella 15W40 (non synthetic) in my diesel farm tractor today. It is a very good oil for what it is designed for, IMHO.
Larry
RedBird is offline
post #5 of 20 (permalink) Old 05-08-2010, 07:41 AM
Main Motorcycle: T100
About time we had another oil thread.....
"You can fool some of the people all the time, all the people some of the time, but you only have to fool the majority of the people for one day every few years and you've got a democracy"...Leunig
Snowbonnie is offline
post #6 of 20 (permalink) Old 05-08-2010, 09:53 AM
Forum Liaison
Main Motorcycle: XT1200Z
BlackTigNYC's Avatar
Other Motorcycle: Duc?
As I've said before, I use barbeque drippings and it works just fine.
It's free and I'm also doing my part for the environment
BlackTigNYC is offline
post #7 of 20 (permalink) Old 05-08-2010, 09:57 AM
Main Motorcycle: 2006 Scrambler #234 U.K.
scramble stash's Avatar
Go
I like this. Good way to start the day. Smile
scramble stash is offline
post #8 of 20 (permalink) Old 05-08-2010, 10:20 AM
Main Motorcycle: '06 Scrambler/'07 BonnieB
cdubya's Avatar
Other Motorcycle: '05 Yamaha WR 250
Extra Motorcycle: '05 Tiger
I'm going skiing and then for a few hour ride on the Scram. I'll be back in about 5 hours to see how this turned out.
'06 Scrambler: De-AI'ed, CARK/Uni Pods, Emgo 12" Shorty's, 145mains, 40pilots, stock needles, no shims
'07 Bonnie Blk: De-AI'ed, CARK/Uni Pods, NH Peashooters, 145mains, 40pilots, no shims
'05 Tiger 955i: No airbox plate, Debaffled stock exhaust
cdubya is offline
post #9 of 20 (permalink) Old 05-08-2010, 11:18 AM
Main Motorcycle: 2010 Thunderbird SE
Overkill0084's Avatar
Other Motorcycle: TBD
nothing good can come of this...
I'm using the same stuff. As I understand things, since I will not be firing it up at sub-freezing temps, it will flow as higher than 5 weight on start-up. Once it's warm, it's a 40 weight. If your worried, be very polite during warm-up. Or add BBQ drippings to thicken it.
Cheers,
Greg
2010 Thunderbird SE
Overkill0084 is offline
post #10 of 20 (permalink) Old 05-08-2010, 12:49 PM
well, oil threads are only worthwhile during the first page.... the other 99 pages are basically variations on a theme... "less filling!... tastes great!"
I've used it for a long time in various motorcycles (not the T6, the earlier version).
improves shifts over some other brands, but not as good as others. Not as cost effective as it used to be - walmart around here has gone up on the price, and the local auto parts stores are edging closer to $30 a gallon for the stuff...
The 15-40 non synthetic was too thick for the tiger, but worked ok in a few hondas (shifting was a bit rough with oil that thick)... even in the hot summer here.
cantilever is offline
Shell Rotella 'T' full synthetic Mmagus Sprint Forum 114 03-15-2014 06:38 PM
Anyone use Rotella T Synthetic? Jglisso Speed Triple Forum 45 04-14-2011 12:51 PM
Shell Rotella Synthetic 4T mdgore Sprint Forum 1 07-09-2007 02:17 PM
Anyone using Rotella 5W-40 synthetic? lovern98 Twins Talk 5 08-05-2005 12:07 AM
Rotella 5-40T synthetic Ramsey1200 Trophy 24 04-12-2005 06:58 PM
