Six speed gearbox - Page 4 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com
Old 10-02-2011, 09:38 PM   #31 (permalink)
Forum Liaison
Main Motorcycle: 04 Thruxton
RumRunner's Avatar
Can't wait to see how this goes...
RumRunner is offline   Reply With Quote
Old 05-24-2012, 12:28 PM   #32 (permalink)
Forum Liaison
RumRunner's Avatar
Phil,
Any update on this project???
Doug
Old 05-24-2012, 01:49 PM   #33 (permalink)
Main Motorcycle: Thrux
Other Motorcycle: Ducati SC1000
+1
Regards Nick
Nick1000 is offline   Reply With Quote
Old 05-24-2012, 01:54 PM   #34 (permalink)
Legend
Forchetto's Avatar
Sounds as if he's got it going OK. See post 2 on this thread:
http://www.triumphrat.net/twins-tech...ed-please.html
Forchetto is online now   Reply With Quote
Old 06-08-2012, 07:38 AM   #35 (permalink)
Well, had the six speed gearbox installed and working on the road since last October. I have probably only covered around 4000 miles
The new gearbox runs brilliantly.
I live in an area with lots of hills and winding roads that gives any gearbox a run for its money. The new gear has performed faultlessly and I am very pleased with the end result. Please remember the extra gear fits between fourth and fifth so it does not change your overall gearing just gives you another one to play with. When you are pulling out of a corner hitting 8000rpm in fourth then fifth and powering up in sixth, its just brilliant and has me rapidly chasing down other twins in front of me.
I have had the overall gearing almost stock for the last few months, 19/44 with 160/60 tyre 135mph@8000rpm in sixth. With the many hills and draconian fines for speeding, I have just reduced the overall gearing to 18/44 129mph@8000 in sixth. This has produced a fantastic snap to acceleration with the front wheel skimming across the ripples in tarmac, I just have to be conscious of the occasional wheelie here and there but life’s good. Lol
I generally do not rev my bike over 7500rpm but yes I have hit 8000rpm in sixth gear. (on private roads officer)
Was the extra gear worth it, difficult to answer, if it could have changed the overall gearing, then yes, but with the gear slipping in between two others, for the road then probably not. But If you’re a Thruxton Cup racer, it would give you a massive advantage.
Was it with the expense, hell yes! Would I sell the gearbox – only if offered the right money, so I could finance other mods
Hava already done a few things to the engine
4mm Oversize inlet valves
2mm Oversize exhaust valves
Ported & flowed head 320cfm
790 Cams
Billet barrels ‐ http://www.stabbarps‐auto.com/welcome.html
1089cc Wiseco kit 10.5‐1 CR pistons‐ http://www.bonnevilleperformance.com/
101mm x 68mm bore & stroke
Rebalanced crank
Barnet racing Clutch
Heavy duty clutch springs
Shot preened gears and shafts
Chromed cases
Phil-1100 is offline   Reply With Quote
Old 06-08-2012, 08:57 AM   #36 (permalink)
Forum Liaison
RumRunner's Avatar
Phil,
Thanks for the info, and for all of your hard work.
Cheers,
Doug
Old 06-08-2012, 12:13 PM   #37 (permalink)
Main Motorcycle: Aprilia Caponord
Other Motorcycle: 2006 Scrambler (sold)
Extra Motorcycle: 1995 Daytona 900 (sold)
Extra gear's between 4th and 5th? Doesn't seem worth the effort to me, but good on ya for doing it, anyway!
bobbo is offline   Reply With Quote
Old 12-04-2012, 03:00 PM   #38 (permalink)
Main Motorcycle: 2010 Scrambler
Other Motorcycle: 2010 XR1200
Extra Motorcycle: 2007 Husqvarna TE250
Awesome!
Now the next question, what does it take to change the gearing of 5th (your 6th)?
midengineracer is offline   Reply With Quote
gearbox main shaft 5 speed Caulky Classic, Vintage & Veteran 6 02-22-2010 09:06 AM
71/72 five speed gearbox RetroRod Classic, Vintage & Veteran 0 07-20-2009 04:22 AM
5 speed gearbox assembly... LukeSmith1985 Classic, Vintage & Veteran 4 07-08-2009 11:53 AM
6 Speed gearbox anyone Phil-1100 Twins Technical Talk 25 05-27-2008 06:11 AM
'04 Speed Triple gearbox Shutter Speed Triple Forum 11 11-18-2005 02:09 AM
