Formula Extreme Favorite Bike: Bonneville 07, "Bonnie"
Posts: 497 Other Motorcycle: Past rides, 66 bonneville Extra Motorcycle: Past rides, 72 bonneville
Additional note
When doing the bafflectomy, especially the grinding with the hole saw part, cover your bike and especially the tire/rim with a dropcloth. When you grind, small metal particles land everywhere and if they end up on your rims, spokes or any unpainted metal, they will rust within a days time.
Use a dust mask for the same reason. Sweep up under the mufflers after you are through or better yet, vacum the dust up.
I used a "remgrit" 1 1/4 inch carbide grinding tool which you can find at home depot or lowes. The cost on those is only about $7 and it works to grind rather than cut it's way through the pipe.
On the 07(mine) the baffle is shorter than the 06's.
I've enclosed pics to help you see the difference.
Bill
Mods: snorkel removed, bafflectomy, jets out 3 turns, summer screen, cortec tank/saddlebags, Bella Corse Highlander bars,Modre peg lowering kit,Drag specialties mini tach, D9 bracket.
Reason: spelling
