kdlutes,
Excellent post; very well done! Did you try to drill through the remaining baffles? You should put this in the Downloads section of the forum. Thanks for a great contribution to the forum.
EL84,
The stock Bonnie out of the crate is set up by the factory to run lean; this is done to meet EPA emission standards. Some folks have rejetted to 112 mains without doing any muffler modifications. Remember, the leaner an engine runs, the hotter (temperature wise) it runs.
To answer your question, no, you would not have to rejet after this mod. Removing the rear baffle does not greatly increase the exhaust flow. Personally, I would rejet to 112's without doing any muffler mods. I am at sea level. That's just my opinion.
If you were to drill out the remaining baffles, you should rejet to, at least, 115's (115's are the size of the jets that come with TORs). I found 118s to be ideal in this scenario as verified by a dyno run exhaust analysis.
Carl S
Old Soldier
