Weird handling problem - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-22-2010, 02:50 AM   #1 (permalink)
Favourite Bike: 07 T100 Black and White
Question Weird handling problem
Just had a weekend away - approx 750 miles done. Early on I finished bedding in a set of new tyres - ContiGo's. Great tyres...around left hand corners!
Going around right hand corners the front end shimmys / wobbles slightly - very unsettling. In left turns a super planted, faster steering (than with OEM Metzler Lasertecs), lovely handling Bonnie, whereas in right turns I get a wobble? What the heck???
Checked the forks - ok. Checked the rear shocks - ok. Checked the chain adjustment - ok. Checked the tyre pressures - ok. Checked the tyres for bulges or bits - ok.
Did more riding...found that:
- Two-up with no luggage - the issue is almost non-existent.
- Solo with about 10kg (22lbs) luggage in a pack on the rear of the seat and preload on my normal 4 of 5 - it happens most right hand corners (unless they're very smooth).
- Solo with same luggage but preload upped to 5 about 3/4 of the wobble goes away.
I've checked alignment as best I can and searched the threads on this forum without coming across this problem anywhere.
Any help or ideas would be greatly appreciated...
Carpe Diem
07 B&W T100, Thunderbike pipes, K&N, lower bars, Oberon bar-ends, Dart flyscreen
c_marcus3 is offline   Reply With Quote
Old 03-22-2010, 07:09 AM   #2 (permalink)
Favourite Bike: 2009 Bonneville SE
Forchetto's Avatar
Check alignment of the tyre and rim. There's a moulded line all round the tyre about 1/4" from the rim's edge. See that this is equidistant all the way round. You can see that line in this example:
Old 03-22-2010, 08:11 PM   #3 (permalink)
Thanks Forchetto
Have checked the alignment for both tyres and on both sides - all equidistant.
Carpe Diem
Old 03-22-2010, 08:31 PM   #4 (permalink)
Forchetto's Avatar
I can only think of inspecting the front forks. See that they protrude the same through the triple clamps, oil quantity the same on both legs, the springs are the same length, that sort of thing.
Old 03-22-2010, 08:45 PM   #5 (permalink)
Favourite Bike: 96 Daytona 1200
Rocket59's Avatar
Maybe your forks are racked slightly to the right.
Rocket59 is offline   Reply With Quote
Old 03-22-2010, 08:47 PM   #6 (permalink)
Favourite Bike: 2000 Triumph Sprint RS
NITES's Avatar
Other Motorcycle: 1996 Trophy 1200
Extra Motorcycle: 99 Kawasaki Drifter 1500
I know this might be a stretch, but one issue could be the rear wheel bearings are wearing or dirty. I had a similar problem with a friend's honda. Mechanic suggested we pop wheel off and clean out bearings and reinstall. Surprisingly it fixed the problem. His logic was if the front tire wobbles during left & right turns, it's the front bearings. If only in one direction, it's usually the back. The back bearings don't get as much attention and sometimes get alot of grime and blacktop goo in there. I'm not sure if that's the solution but hope it helps.
NITES is offline   Reply With Quote
Old 03-22-2010, 08:52 PM   #7 (permalink)
Favourite Bike: 05 T100
Assuming you didn't have this problem before you changed tyres, didn't alter your fork set-up at the same time, and although you've "checked alignment as best I can", I would have a closer look at your wheel alignment.
Paul.
Herts. UK
Old 03-22-2010, 08:58 PM   #8 (permalink)
Favourite Bike: '52 Vincent B/L
Flaco's Avatar
Other Motorcycle: '05 Bonneville
Extra Motorcycle: Past / '65 TR5
A+
What paas said...
'05 Bonnie, 73 RWHP "Goodwood Green Chili Dancing Machine."
Flaco is offline   Reply With Quote
Old 03-22-2010, 11:24 PM   #9 (permalink)
Thanks, that gives me some things to go on with. I hadn't altered the fork setup but will check them anyway and look at the wheel bearings and alignment. May have to go back to the shop for that...
Carpe Diem
Old 03-23-2010, 08:52 AM   #10 (permalink)
Favourite Bike: 2010 R3 Roadster
fat frank's Avatar
If it wasn't noticeable with the old tire, I'ld have another look at that front tire. There could be blems there that are hard to see. Or, maybe just a bad install.
Good luck and let us know what you find.
fat frank is offline   Reply With Quote
Help please... Weird problem. CrazyIvan Sprint Forum 16 12-22-2008 06:26 PM
weird brake problem. pls help! Tommo Twins Talk 14 04-25-2007 11:10 AM
Really Weird Problem Syderange Hinckley Classic Triples 3 04-20-2007 08:03 PM
Sudden handling problem with my Thruxton hyperview Club Cafe' 11 09-19-2006 05:20 PM
weird problem Ruthwell Twins Technical Talk 7 08-25-2006 11:39 PM
