Site Supporter SOTP Vintage Series Favourite Bike: 2009 Bonneville SE
Posts: 6,865 Other Motorcycle: Yamaha XV1100 Extra Motorcycle: Qingqi QM200GY-BA
As your battery was well discharged, connecting a 50 amp charger to it probably means the plates have overheated and distorted and are permanently damaged. In its discharged state the battery tries to absorb all the current you care to give it and that charger gave it all.
After 8 months of inactivity the carb needle valves that control the flow of gas into the float chambers were probably stuck. There should be an overflow device on those carbs, though it could be blocked with dirt, and the excess fuel flowed into the airbox.
