LM2 air/fuel gauge question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-21-2010, 11:50 AM   #1 (permalink)
Favourite Bike: 05 speedmaster - black
Other Motorcycle: 2010 Thunderbird
my Inovate LM2 kit arrived (a month after ordering it). I got the port welded on and the power plug setup. I want to hook up the tach function, I see which lead on the LM2 input to use (blk/white stripe) my questions is where is the best / most convenient place to pick up the tach signal? can I use the lead to the bikes tack?
see my wicked black speedmaster
904cc, 12:1 JE racing pistons, thunderbike cams, ported and polished head, scepter pipes, 39mm FCRs.
mag10 is offline   Reply With Quote
Old 03-21-2010, 07:49 PM   #2 (permalink)
B02S4's Avatar
I have a kit on order from Jegs, who did you order yours from?
B02S4 is offline   Reply With Quote
Old 03-21-2010, 08:46 PM   #3 (permalink)
Favourite Bike: scram 865 ī07
twinfan's Avatar
hi mag
i have lm-2 here, too...i heard of lots people having problems getting a signal from the rpm input...
so i first did some tests at home with a frequencegenerator...the rev counter gets frequencies from 0 to round about 140hz...itīs just the frequence that changes...
whereas 140hz is for a pieman igniter with 8500rpm
you need a voltage of 13.6V rectangle...
http://img125.imageshack.us/img125/8189/osz3fn3.jpg (red channel is the rev signal...in this case 25,4hz @ 1520rpm)
pluging the lm-2 via usb cable to your pc and connect it to the software will show you the revs on the software gauge...
now you know if it works or not...so it must work on the bike, too...in the manual you can read that they recommend using a 100k potentiometer, when you have problems with getting a signal
try to keep as much distance as possible to the high voltage zone (coils, plugs) to prevent interferences/disturbances
as i even want to log my tps signal and donīt want to split the analog cable...i use some safety pins...i stick them through the gaskets of the cables and put them in directly at the igniter
http://img501.imageshack.us/img501/8053/zbox1ee2.jpg
15 (red) is rev
17 (green/yellow) is tps
cheers
twinfan
twinfan is offline   Reply With Quote
Old 03-22-2010, 10:21 AM   #4 (permalink)
Fuel Systems - they have a turbo/supercharger shop near me. some cool stuff in there for drag cars.
Old 03-22-2010, 10:29 AM   #5 (permalink)
thanks twinfan - your right it does work on the PC every time. on the bike not so much. I am going to try the connect under the tank nacelle to see what that does.
low fuel light/fuel gauge malfunction keystiger Tiger Workshop (archive) 16 05-19-2010 01:05 PM
Fuel Gauge miket The Rocket Science Forum 5 06-03-2008 10:51 AM
Fuel Gauge Low Fuel Light problem any ideas ? CYNCRZR Sprint Forum 4 06-10-2007 12:36 AM
Fuel Gauge OK, Low-Fuel light intermittent andy-D Tiger Chat 3 11-16-2006 05:46 PM
Fuel gauge question Chyron Tiger Workshop (archive) 4 07-08-2005 02:16 PM
