Progressive Fork spring kit help...
I started to install the 1" lower Progressive spring kit on my 07 t100
They progressive instructions say i have to remove the damper rod to ADD qty-1 small progressive spring to the damper rod (and keeping the stock damper spring as well)
I cannot for the life of me take out the Damper rod screw on the bottom of the fork (they must have used lock tite devils grip!) plus i just have the L shaped 8MM hand tool with not the best leverage
but when i search these forums, it seems every one is just changing the main spring and spacer, no talk at all about adding one of these springs to the damper rod.
do i need to add that damper spring for the t-100 ?
