Bonneville A1: Scottoiler 'Lube Tube' placement - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-17-2010, 05:06 PM   #1 (permalink)
Favourite Bike: 09 Bonnie A-1 Black
Sparky's Avatar
Other Motorcycle: '84 H/D FXRP
First off, I promise that this will be my last Scottoiler question. I swear!!!
I'm wondering if anyone has found a decent spot to utilize this on a standard '09 EFI Bonneville. I'm kinda stymied at finding an appropriate location.
Any help would be greatly appreciated...
-Sparky
Predators, Riccor Intimanators, Ikons, AI gone, Chainguard gone, Scottoiler, Clocks4Bikes clock, Tank pads, 42,000 on the clock.
I don't always ride a motorcycle, but when I do I prefer TriuMPH. -Ruger
Sparky is offline   Reply With Quote
Old 03-17-2010, 05:16 PM   #2 (permalink)
Favourite Bike: Can't decide now!!
Ventura's Avatar
Other Motorcycle: Scram + Thrux
Extra Motorcycle: '71 BSA Thunderbolt
Im not sure how much the under-seat arrangement differs between Carb'd and EFI bikes, but I have a lube-tube on my Scram.
Its loosely placed in the space directly behind the battery, folded in half.
Has worked fine there for the last 7000 miles.
That reminds me, I must check to see if it needs refilling!
V.
2006 Scrambler, VARK'd, 155/40, 790 In-cam, Pieman'd igniter, DNA Pods, Zard 2:1.
2005 Thruxton, Black now, with ARK, FCR 39's & Uni's, Retimed 790 cams, Barnett clutch and suchlike!!
Ventura is offline   Reply With Quote
Old 03-17-2010, 05:18 PM   #3 (permalink)
Favourite Bike: Bonnie Black Special
PieMan's Avatar
Mine is attached to the left hand frame down tube just to the rear of the left side panel.
I just have to glance at it to see if it needs refilling.
Mike (UK)
04 Bonnie Black
PieMan is offline   Reply With Quote
Old 03-17-2010, 05:19 PM   #4 (permalink)
Sparky's Avatar
Lube Toob
Ventura,
I wasn't aware it could be folded in half!
Any chance you'd be able to post a photo? I'd sure appreciate it
Thanks,
Sparky
Old 03-17-2010, 05:57 PM   #5 (permalink)
Ventura's Avatar
Originally Posted by Sparky View Post
Ventura,
Just to be clear, you are referring to the sausage-like add on that acts as a secondary resevoir to the Scottoiler?
And not the RMV itself?
If so then the Lube-Tube can be placed anywhere and can adopt any shape that you want it to.
As long as its not overfilled then it can be manipulated into any cubby hole or space there is, no matter its shape.
Mine is folded in half and lays across the bike, just behind the battery, between the seat location lugs.
My RMV is strapped to the right hand frame down-tube, just above the chain.
Easy to see the level there, but with the lube-tube fitted then that is always full.
I think there's a thread on my install somewhere.
Unfortunately Im away from my bikes for another week.
Wouldnt be able to post photo's till then.
V.
Old 03-18-2010, 04:07 PM   #6 (permalink)
Are you talking about the hook up for the vacuum line to operate the oiler valve?
The FI bikes only have two vacuum ports, one on eaither side of the intake side, if so put a "t" in the line and run the vacuum tube to the "t".
larryshep is offline   Reply With Quote
Old 03-18-2010, 04:29 PM   #7 (permalink)
Favourite Bike: Triumph
johnyC's Avatar
look in the stickies
don't tee into the map impulse lines, use the tapping point on the inside of the rhs throttle body, the one nearest the cylinder head.
johny. the boy's happy, leave him alone.
johnyC is offline   Reply With Quote
Old 03-18-2010, 04:30 PM   #8 (permalink)
Favourite Bike: 2009 Bonneville SE
Forchetto's Avatar
Don't. Those vacuum ports on top of the inlet manifolds are connected to the two MAP sensors. Anything connected there, or even worse connected together with a "T" piece would muck up the engine management real good.
There are two vacuum take-off points under the throttle bodies.
Old 03-18-2010, 05:41 PM   #9 (permalink)
Favourite Bike: 09 Scrambler
Other Motorcycle: Like an 04 Thunderbird
Johny, I've connected mine to the RH Throttle body vac connector point as you mention (closest to the cyclinder head and quite a pain to get to) on my 09 Scram, and it's provided good consistent chain oiling from my Scottoiler once I adjusted the flow rate correctly.
One point I wanted to raise was that the other day I rode the bike a bit harder than usual (i.e. spending a lot of time around the 5/6K rev range) and I notied that when I got home the oiler had almost completly emptied over about 40 miles and my rear tyre and wheel were absoluetly covered in the blue oil?
Is there a chance that this specific vac connector generates a little too much vacum when the engine is worked hard, whch is why Scottoiler recommend the left hand throttle body vac point, even though it doesen't generate any vac worth talking about below 3K revs?
Confused...
Cheers
Steve
Steve Block is offline   Reply With Quote
Old 03-18-2010, 06:00 PM   #10 (permalink)
johnyC's Avatar
look in the stickies!
Steve,
The vacuum drops if you open the throttle more, look at the little video I posted. The most you can pull is what's available in the inlet manifold, where vacuum is at it's strongest on a closing throttle (provided it's tapped into the inlet manifold downstream of the throttle) If you've been dumping oil on your tyre, it's either broken or it's opened up too much. Mine has been working flawlessly for nearly a year now, at about 30% open from fully closed.
ps. here's the link to the thread http://www.triumphrat.net/twins-tech...fi-bonnie.html
Bonneville fork tube size atlantaallen Twins Technical Talk 4 10-15-2009 04:27 PM
Gas tank drain tube and breather tube coachsburke Sprint Forum 12 09-10-2009 11:57 AM
New Speedo Cable - To Lube or Not to Lube oregonthruxton Twins Technical Talk 4 04-30-2008 10:58 AM
AI removes LEFT tube but what is the RIGHT tube for? ocguyocguy Twins Technical Talk 2 01-27-2007 12:10 AM
To Lube the chain or not to Lube...that is the Question Clanrickarde Twins Talk 27 02-25-2006 09:37 AM
