Checking Oil on Centre Stand... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-15-2010, 09:38 PM   #1 (permalink)
Favourite Bike: Bonnie SE
Nogerelli's Avatar
Other Motorcycle: YZ 250
My SE is my first bike ever with a centre stand, and I have a question that I can pretty much answer with some common sense, but figured I'd throw it out there to you knowledgeable Bonnie guys for a definite answer.
Can you accurately check the oil level in the sight glass with the bike up on the centre stand? The only mental adjustment I can tell one would have to make is to be aware that the oil in the glass will appear slightly pitched, because the rear wheel is off the ground a couple of inches. I don't see any reason why the oil can't accurately be checked, but someone out there may know better.
Nogerelli
"I'm trying to ride this motorcycle without bloody well killing myself." ~ Michael Carrington
Nogerelli is offline   Reply With Quote
Old 02-15-2010, 10:07 PM   #2 (permalink)
Favourite Bike: 2009 Bonneville SE
Buckshot's Avatar
I think it would be fairly accurate, like you said, you'd need to take the angle into account. Just curious, where did you get your centerstand?
Buckshot is offline   Reply With Quote
Old 02-15-2010, 10:54 PM   #3 (permalink)
Nogerelli's Avatar
Ordered it from Jack Lilley Triumph over in the UK. With shipping it came to $267 USD... I probably could have gotten it a little cheaper stateside but their customer service is great.
Old 02-16-2010, 08:02 AM   #4 (permalink)
Favourite Bike: Thruxton
I really do not check my oil level too often because it does not leak or smoke, but if a bike is relatively level - such as resting on a center stand, the level in the window will be accurate.
davidc is offline   Reply With Quote
Old 02-16-2010, 08:33 AM   #5 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
Center stand is fine
You have to check the oil while the bike is straight up, this is one of the reasons you have a center stand.
I've been doing it that way for five years, no problems.
Note that the oil needs some amount of time to settle after you run it or add oil, before you check the level.
Marty
Old 02-16-2010, 10:12 AM   #6 (permalink)
Loose Head Administrator
Supernova
propforward's Avatar
Likewise - I check mine on the centerstand. For kicks I had a looky while holding the bike upright off the stand - damn close to the same level, but harder to do.
So - there you are. Checking oil level on centerstand is fine, just like Marty says.
Rule 1: Cardio
Rustic Road Progress
Old 02-16-2010, 10:31 AM   #7 (permalink)
Nogerelli's Avatar
Thanks guys!
Old 02-16-2010, 12:52 PM   #8 (permalink)
Favourite Bike: 05 Black Speedmaster
As long as the surface that the stand is on is level of course.
Wot...no centre stand? BluprintZ Twins Technical Talk 19 10-13-2010 06:54 AM
Side Stand or Centre Stand??? dryheat Twins Technical Talk 14 08-12-2008 06:47 PM
Centre stand mikey Sprint Forum 1 02-21-2007 09:48 PM
Centre stand CaptRussell Classic, Vintage & Veteran 1 05-02-2006 11:23 PM
centre stand tango Tiger Chat 0 03-24-2004 09:13 AM
