Originally Posted by B02S4
Uni does not recommend running their filters dry or with motor oil.
A uni filter crankcase breather is going to get drenched in engine oil, like it or not...
Any filter will eventually get oiled up by the crankcase breather, and as a crankcase breathes *in* and *out*, it's safer to use the same oil on the filter as you run in the motor.
Ergo ... I use Motul 7100 synthetic on the filter.
S.
