Stage 1 re-map? - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!Ontario Tourism
Old 02-12-2010, 12:29 AM   #1 (permalink)
Favourite Bike: '05 Triumph Speedmaster
HIGHWAYSTAR's Avatar
Other Motorcycle: '06 Kodiak 450 Quad
Extra Motorcycle: '06 Bruin 350
Stage 1 re-map?
I need to be educated on this mod to see if I need or want.
Has anyone done the 270 degree rev limiter and remap from Triumph twin power and if yes, what do you think of the upgrade?
Would this re-map make a noticable difference?
2005 SPEEDMASTER- K/N carb kit,DNA Filter Pods, 17T Sprocket, Thunderbike Pipes, Leather Neck Jim Saddle bags and a tasteful amount of Chrome.
2008 Lotus Exige S240(4 wheel Crotch Rocket)
2006 Kodiak 450
HIGHWAYSTAR is offline   Reply With Quote
Old 02-13-2010, 11:44 PM   #2 (permalink)
Favourite Bike: T100, number 24
woodwardpj222's Avatar
not the 270 but
I had the mod done for my T100 ignitor (REV limit and remap) which is not the same motor but worth comment.
For your machine the REV limit is probably not as important as the ignition map. Not because you don't ride hard but because on your style of machine you are generally not going to have the thing tapped out all the time.
The ignition map will give you better bottom end and midrange and also some change top end (depending on how it breathes).
I reckon it was worth the money IF you go for REV limit AND remap.
Woody ... go hard or go home
woodwardpj222 is offline   Reply With Quote
Old 02-14-2010, 11:04 AM   #3 (permalink)
Yes, I would have both Rev and re-map done if it gave a more responsive behavior to the throttle.
I do ride my S/M hard, not race track day wild man hard but I will take it to the limit on a regular basis.
Over here the highways are very accommodating for quick starts and high sustainded speeds.
So do you feel it was money well spent? Did you notice the difference after you had it done and would you order again if you needed to?
2006 Kodiak 450
Old 02-16-2010, 09:41 AM   #4 (permalink)
That was a yes
OK Highwaystar,
That was a yes.
As you are obviously a hard charger that's a double yes.
No it's not going to make your bike suddenly tear your arms off but yes a significant enough difference to bottom end, midrange, top-end as well as REV peak. It will also pull a higher gear better.
I didn't dyno mine specifically on this mod.
All performance gains are relative so the best way to say it is it's a good value gain.
Old 02-16-2010, 09:53 AM   #5 (permalink)
Favourite Bike: 2004 Thruxton
Other Motorcycle: 1971 BMW R50/5
Extra Motorcycle: 1971 CB350
My '04 thruxton picked up a dyno documented 0.5-1 RWHP from 3,000 rpm & up with the pieman remap/rev limit increase when compared to a procom ignitor. YMMV.
--Rich
EDIT - the documented gain was 1-2 RWHP from 5500 rpms to redline.
beemerrich is online now   Reply With Quote
Old 02-16-2010, 03:22 PM   #6 (permalink)
Favourite Bike: 08 Bonneville T100 C/S
wenzel850's Avatar
Other Motorcycle: 05 T100 R.I.Pieces
Rich,
Are you saying and additional 05-1 rwhp was gained over what you had already gained using the Procom ?
So what was the total of hp gained if you know ?
I'm going to be doing this upgrade very shortly and was just wondering !
Quentin
wenzel850 is offline   Reply With Quote
Old 02-16-2010, 05:17 PM   #7 (permalink)
Yep, the gains are on top of what the procom offers. Looking back, I see that I mis-spoke earlier in this thread...the HP gains are closer to 1-2 RWHP from about 5500 to redline. Here's the dyno comparison/discussion thread:
http://www.triumphrat.net/twins-tech...-thruxton.html
I did do back to back tests on the stock ignitor vs. the procom, but couldn't do stock vs. pieman since the stock was an 865 ignitor and the pieman remap is for the 790 cams I put in the bike. The procom only made maybe 1/2 RWHP more than the stock ignitor across most of the range, with a bit more than that up top since my procom didn't have a limiter - or none that I ever found when running it up to about 9,000 rpms (not on purpose).
The pieman remap is clearly a worthwhile upgrade and lets you make the most of the $$s spent on airbox removal/pipes.
Cheers,
--Rich
Old 02-16-2010, 08:35 PM   #8 (permalink)
Thanks boys,... thats what I wanted to hear, an affirmative yes! Sounds like it should sharpen it up a bit with a touch more hp and all this for an affordable price too!
Im waiting for my DNA pods to show up and then Im going to have this upgrade done.
Man I love this bike!
2006 Kodiak 450
Stage 2 mrwog Daytona Deliberations 2 05-12-2009 02:53 PM
Stage 1 Is Done - What Next ? geoff.hardiker Twins Technical Talk 4 09-10-2008 10:40 AM
stage 1 cam wildchild Twins Technical Talk 43 05-30-2008 10:35 AM
Stage 1 of my S3 church Speed Triple Forum 35 06-12-2007 09:54 PM
stage III donnydildo Club Cafe' 2 03-27-2006 08:35 AM
