Why is my gasoline orange? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 8 (permalink) Old 12-12-2009, 02:11 PM Thread Starter
Main Motorcycle: 2007 Thruxton
sbpark's Avatar
i think i already know the answer to this questoin and don't want to believe it. i know the gas was clear when it went into the tank from the pump, but recently noticed it is an orange (rust?) color when i remove the float bowl nut to drain the carbs on my FCR's.
i really hope my tank isn't rusted. i cant see how or why it would rust. the bike is exactly 2 years old (factory warranty expired literally 2 weeks ago).
curious to see what others think the problem is, and if it is rusted is this a warranty claim?
'07 Thruxton, Caspian Blue Checker, FCR's, 813 cams, Pieman ignitor, Predators, ported & polished head...
sbpark is offline
post #2 of 8 (permalink) Old 12-12-2009, 03:07 PM
Main Motorcycle: 04 Bonnie black
If you always have gas in your tank,[living where you do,I`ll guess yes],then your tank shouldn`t ever rust unless it sits for months or more. The gas up here looks clear going in,but is always some color when I pour it out.Gold,honey,light orange,sometimes purple,it just depends on the different brands additive package,and octane.If it runs good,I wouldn`t sweat it.
rodburner is offline
post #3 of 8 (permalink) Old 12-12-2009, 05:57 PM
Main Motorcycle: THRUXTON
CHRIS211083's Avatar
OK, here i come to rescue or to finish you off. fill your carbs with the fuel and leave it over nite(if there still on the bike). Crack open the bleed screw or bolt on the bottom of the carb. if the fuel comes out rust coloured and then goes clear then you have rust, however. If the colour stays orange then its an additive. Problem solved!!! Also if the tank is rusty then you should be able to see rust in the tank as it must build up before it flakes off into the petrol. Im either a life saver or heart braker. hope this helps.Chris.
CHRIS211083 is online now
post #4 of 8 (permalink) Old 12-12-2009, 06:41 PM
Main Motorcycle: 03 T100
mikeinva's Avatar
PS stop p--ing in the tank lol. I bet the tanks ok.
mikeinva is online now
post #5 of 8 (permalink) Old 12-12-2009, 08:26 PM
Cool
I thought it might have been Tang
mozart is offline
post #6 of 8 (permalink) Old 12-13-2009, 10:42 AM
Main Motorcycle: 2006 Bonneville T100
road dog's Avatar
Other Motorcycle: 2002 ThunderBird 900
Extra Motorcycle: 1982 CB900F SuperSport
I would doubt it's actually rust. If it is... well, you already know the answer to your warranty question.
road dog is offline
post #7 of 8 (permalink) Old 12-13-2009, 12:25 PM
Main Motorcycle: 2006 Thruxton Caspian Blu
ocguyocguy's Avatar
Other Motorcycle: H.D. and Honda
Extra Motorcycle: MX, off road, Enduro
Gas changes color as it gets older.
How old is that gas? I noticed the other day working on a dirt bike of mine (plastic tank no chance of rust) that the clear gas I had put in now looked a "rust" color...it was there maybe a month and a half...I also had trouble starting the kick start only bike so I drained the tank and put in some new clear color gas. I know the color changes after awhile and also does not fire as well but I am not sure how long this color change happens. I would not worry about it if I were you. Your tank is not old enough to have rusted I don't believe.
I also have used that product "Sea Foam" and it does work cleaning out old gas and such.
ocguyocguy is offline
post #8 of 8 (permalink) Old 12-13-2009, 04:37 PM
grayghost's Avatar
Talking
Okay....I'll bite.
Why IS your gasoline orange?
" My bike pulls to the left......or the right....depending on what side of the road the Tim Hortons is on"
grayghost is offline
What type of gasoline do you use? Decker Twins Technical Talk 58 06-17-2009 01:30 PM
Gasoline In Tank? Stealth Twins Technical Talk 14 08-23-2007 07:46 AM
Gasoline is getting really bad. TOMKRILL Twins Talk 56 08-07-2007 12:40 AM
City Gasoline vs Country Gasoline dawgfan Twins Talk 7 06-19-2006 06:51 PM
What Gasoline does everyone use and why? BillyRaff Twins Talk 23 05-09-2006 10:16 PM
