Anyone who has this particular model? I need to know what you did foe the rear support bolt. It appears to line up with one of the frame bolts, a 17mm hex 10 by 1.25. The bracket appears to be at least one inch away from the frame , making the original bolt too short and what to do for a spacer this thick. Not to mention that once the exhast is sitting in the correct space you can't hardly get a wrench on the bolt. Am I doing something wrong here. I don't know if the other Zard low has the same support point.
Related Threads
Triumph Rat Motorcycle Forums
3.9M posts
167.7K members
Since 2002
