T100 jetting question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-21-2009, 01:47 AM   #1 (permalink)
Favourite Bike: 03 T100
Other Motorcycle: 98 TBS
I bought an 03 T100 last month and have about 1000 mi on it so far. I just came across a receipt in the owners manual for a Unifilter and a jetting kit [42/125/4], as well as the AI bolts. The bike has NH Togas. If I were going by the Jenks guide this seems right on the money(except for the 4 turns out). But if I use Ventura's guide it seems like I should be at 40/120/1 shim & 1 turn.
I know this has been discussed at length and I apologize if this is a stupid question but I have read these threads til I'm dizzy and feel like I must be missing something obvious. So which jetting should I go with or do I really need to invest in having it dynoed?
Bike seems to pull very strong up top, not as strong as I would expect in mid-range and takes at least 5 full minutes on full choke before idling on its own.
Any suggestions welcome. Thanks
hs3000 is offline   Reply With Quote
Old 11-21-2009, 01:54 AM   #2 (permalink)
Favourite Bike: 2007 Thruxton
sbpark's Avatar
shouldnt be 4 turns out on the mixture screws. try 42's with 2-2 1/2 turns out.
'07 Thruxton, Caspian Blue Checker, FCR's, 813 cams, Pieman ignitor, Predators, ported & polished head...
sbpark is offline   Reply With Quote
Old 11-21-2009, 02:36 AM   #3 (permalink)
Favourite Bike: Can't decide now!!
Ventura's Avatar
Other Motorcycle: Scram + Thrux
Extra Motorcycle: '71 BSA Thunderbolt
Have you checked that your airbox is still fully intact?
Is the restrictor plate (magic iris!! ) still in there?
This will have great bearing on the matter, and if its still in there then your " [42/125/4]" settings could be somewhat rich.
Those settings of mine which you quote are exactly how I had to set my bike, when I tried those particular mods, in order to maintain as close to 13:1 A/F as possible.
(all at sea level).
Its up to you if you choose to use them as a guide when applying them to your particular set up, but in my case they were as near to spot-on as I could get it, using an A/F sniffer as my guide, and all taken during general riding conditions.
V.
2006 Scrambler, VARK'd, 155/40, 790 In-cam, Pieman'd igniter, DNA Pods, Zard 2:1.
2005 Thruxton, Black now, with ARK, FCR 39's & Uni's, Retimed 790 cams, Barnett clutch and suchlike!!
Ventura is online now   Reply With Quote
Old 11-21-2009, 04:40 AM   #4 (permalink)
Unklian's Avatar
Perhaps 42/125/4
= 4 shims? 2 under each needle?
Ian.
Unklian is offline   Reply With Quote
Old 11-21-2009, 07:08 AM   #5 (permalink)
sbpark- I assume (yeah, bad idea) that the 4 means 4 turns out on the mixture screws. I haven't tried setting them yet, Maybe have time to check them today.
Ventura- I forgot to add that the snorkel has been removed, restrictor plate is still intact. I realize that your settings may not be perfect for my bike, but considering how much work and testing you have done I figured it would get me very close. Do you know what differences would result in the separate setups that you and Jenks came up with?
Ian- I had not thought of that. Thankfully the po replaced the carb screws with allen heads so it should be an easy job to verify needles. If the mixture screws aren't at 4 turns, that will be what I check next. 4 shims seemed really high so I just thought it must be turns...but I guess 4 turns out is also pretty high.
Old 11-21-2009, 08:06 AM   #6 (permalink)
Unklian's Avatar
Can't remember if the shims are 0.5mm or 0.25mm
If there ARE 2 under each needle, it will only be lifted a maximum of 1mm.
If you look for a picture of a needle and look at the minute taper to them, lifting it evem 1mm is a minute adjustment.
Some other carbs I've seen with the old circlip type adjustment
must alter the needle height by about 6-8mm
Have never heard of idle mixture screws 4 turns out.
Good luck with the messin' about though.
Ian.
Old 11-21-2009, 08:12 AM   #7 (permalink)
sbpark's Avatar
with the CVK's i thought a sort of general rule of thumb was if you go more that 2.5-3 turns out you should go up a pilot jet size and see if that works better.
i've never had good luck shimming the CVK's. my bike always performed better with no shims. even just one shum madde it too rich in the low end.
Old 11-21-2009, 08:12 AM   #8 (permalink)
Ventura's Avatar
HS, there's no reason why your settings shouldnt be fairly close to mine for similar mods.
At the moment your probably running a bit rich across the board, your bike will no doubt start very well but be overly rich low down, your fuel consumption will be increased and you'll be down a little on performace.
Nothing too drastic, but could probably be fine tuned to be nearer optimum.
All in MHO of course!! Hope that helps.
V.
Old 11-21-2009, 02:39 PM   #9 (permalink)
Favourite Bike: T140 Bonneville
gumpt1oo's Avatar
Other Motorcycle: T100 Bonneville
Go with Ventura's set up. I have a T100 and had the same set up as you. Hyde Togas, unifilter, snorkel and AI removed. I jetted it as the jenks guide, had it dyno'd and the AF was way rich at 11:1 across the board.
I have now got an A/F guage fitted to my bike. I have now modified the air box like Ventura to a double entry airbox with the restrictor plate removed and I am still on 40 pilots.
We're all doomed!
gumpt1oo is offline   Reply With Quote
Old 11-21-2009, 03:02 PM   #10 (permalink)
Ok, so I checked the mixture screws and they actually were between 3 1/2 - 4 turns out! Pulled the needles (can't believe I could do it without removing the tank) and I have 1 shim under each. I turned the mixture screws to 2 turns out and will wait to see how that feels.
Strange but by all accounts I should be running a little rich, yet I have been averaging 50mpg in mixed riding.
Thanks for all the help. I will report back after a thorough sotp test!
06 t100 jetting readyjetty Twins Talk 12 01-16-2007 09:04 PM
jetting a t100 kj4nt Twins Technical Talk 0 10-11-2006 08:13 PM
T100 jetting & differences between T100 & Thruxton engines. Nourton Twins Talk 4 05-17-2006 05:48 AM
'05 T100 Jetting... Clifford Twins Talk 3 08-06-2005 02:31 PM
yet another jetting question - a T100 with Thruxton needles billstokes Maintenance & Workshop Talk 5 02-18-2005 06:19 PM
