EPG Moto
Old 11-20-2009, 11:08 PM   #1 (permalink)
Favourite Bike: 2007 Thruxton
sbpark's Avatar
What's your jetting for your FCR's?
just wondering what those of you who live at sea level are using for jetting of your FCR's? i have the FCR's on my thruxton, 865 motor, 813 cams, ported and polished head with 5 angle valve job, predatirs, ARK, UNI filters...
what are your main jets, pilot lets, how many turns out on your slow air screws and idle mixture screws?
thanks everyone!
'07 Thruxton, Caspian Blue Checker, FCR's, 813 cams, Pieman ignitor, Predators, ported & polished head...
sbpark is offline   Reply With Quote
Old 11-21-2009, 06:29 AM   #2 (permalink)
Front Row Moderator
Favourite Bike: 2007 Bonneville Black
propforward's Avatar
Other Motorcycle: ZX1100, KLR650, CB750,
Extra Motorcycle: Matchless G12 DL
I'm currently running
55 slow, 138 main, FBR needle clip on posn 4. This runs well for me in the cold temperatures. Once it gets back up above 60 degrees I use the EMR needle with clip on position 6.
Get your TriumphRAT.net stickers here
Old 11-21-2009, 09:58 AM   #3 (permalink)
Favourite Bike: 2001 BONNIE
fcr set up
Hello again sbpark,
I responded to one of your earlier lines, my set up was determined with the use of the AF gauge I spoke about.
I use Domminator touring pipes and Uni filters, head is stock.
I have an early 2001 790 Bonnie, for some reason my bike set up differently, what it is cams, heads, I don''t know, but I haven't ruled out faultly fuel pump adjustment yet. I plan on making the fuel pump manuel, off of the throttle in the spring. You can reach in behind the heads and push the plunger down with your finger.
So having said that, my set up is as follows:
The following set up ran well at 30.3 in pressure 75F 50% rh, I'm 300-600 feet above sea level normally.
Needle DVR slot #5 from top
Main 148
Slow jet 55
Main air jet 200
Fuel screw 1 5/8
Air screw 1 1/2
Idle screw left 1
Idle screw right 1
As I mentioned before you need to find and be able to change all of the above. It takes a while to learn what items effect the various areas of the AF curve.
When you adjust the air and fuel screws, before you do, scribe a line as a reference to move from, I have found that 1/8 turn adjustments are enough when you're close in this area of the AF curve.
Keep at it
Hoopla
Investing in a better Bonnie one step at a time
HOOPLA is offline   Reply With Quote
Old 11-21-2009, 08:47 PM   #4 (permalink)
sbpark's Avatar
wow, 72 views and only 2 replies?! i know everyone's jetting will be different since a lot of us have different mods, displacement, etc, but c'mon!
anyway, i think i finally got the carbs dialed in fairly well. started a seperate post on what i ended up with and how i got there...
Old 11-23-2009, 01:59 PM   #5 (permalink)
I'm not surprized that you got so few responces, cause I don't think many people have tuned their own carbs.
The responces you do get are good in general, don't hope for an exact set up that's why you need to get an AF gauge or spend lots of time on the dyno.
Hoopla
Old 11-23-2009, 02:42 PM   #6 (permalink)
Favourite Bike: 03 T100
mikeinva's Avatar
Hoopla
+1 on that and one thing that all of us that know alittle about tuneing motors there is no one size that fits all thats why its called tuneing.what works on one guys bike may be way off on anothers.
Old 11-23-2009, 04:36 PM   #7 (permalink)
Favourite Bike: 04 Bonnie Black
PieMan's Avatar
These are the details of an 865 running FCR39's.
Staintunes, DNA Pods, Keihin FCR39's, headwork, Wiseco 10.5:1 pistons, 813 cams, Igniter mods.
145 mains
55 pilots
OC-EMR (pos 5)
P1.5
A1.75
Mike (UK)
04 Bonnie Black
PieMan is offline   Reply With Quote
Old 11-23-2009, 05:07 PM   #8 (permalink)
sbpark's Avatar
those numbers look great with that set-up with the higher compression on the stock motor.
Old 11-23-2009, 05:18 PM   #9 (permalink)
mikeinva's Avatar
Thats pretty good mike what did the head have done to it? os valves?
Old 11-23-2009, 05:27 PM   #10 (permalink)
PieMan's Avatar
Porting with OEM valves.
Mike (UK)
04 Bonnie Black
SYNCING FCR's HOOPLA Twins Technical Talk 1 08-12-2008 09:34 PM
switching out CR carbs dor FCR's... sbpark Twins Technical Talk 1 08-08-2008 07:51 AM
Bl@@dy Keihin FCR's 22856 Twins Technical Talk 6 07-29-2008 06:08 AM
Talk me out of FCR's!!! oil-spitn-rat Hinckley Classic Triples 4 06-05-2008 11:47 PM
FCR's or Mikuni's bonnieblackinfl Twins Talk 33 02-13-2007 08:02 AM
