11-19-2009, 05:12 AM
Formula Extreme Favourite Bike: Bonneville
Posts: 490 Other Motorcycle: 2011 Rocket Roadster
How wide can the handle bars go with stock cables.
How wide can the handle bars be without firrting new cables if the cables are re routed outside the forks.
I think the stock bars are close to 28 ins wide.I like to go to about 33 ins wide.
2001 790, A1 removed, K&N Air filter, restrictor plate removed, air box intake cover enlarged, stock needles one shim, 135 mains, 40 pilots, NH Classic Toga Mufflers - no baffles, Twin Power remap stage 1, 19T, NH Western bars, Dart flyscreen.
11-20-2009, 05:40 AM
Should just about stretch if you use low bars. I've had a pair of LSL Roadsters (not quite 33ins wide) on with no problems using stock cables, but if you're thinking about wide AND high like NH Westerns, then you would ideally need to get longer cables.
11-20-2009, 06:15 AM
Powerbike Favourite Bike: T100
Posts: 341 Other Motorcycle: Fazer
I have 32 3/4" bars end to end ,with stock cables and it was very tight but it does work with no over stretch .
11-21-2009, 05:00 AM
I have NH Westerns and cables I purchased second hand, it looks like a bit of job to replace the cables so was going to look for something of similar style but use the orginal cables.
I think have read somewhere that there are HD bar similar to the NH Westerns but a not as wide.
11-21-2009, 06:32 AM
Grand Prix 500 Favourite Bike: Tiger 800 abs
Posts: 104 Other Motorcycle: 2011 America
I have black Harley bars (flat track style) on my T100. They measure 31" wide or 33" including bar end weights. All cables etc are left as standard, just a little re-routing reqd.
The Harley item code is 56085-83A (handlebar, black wrinkle)
Regards - Adrian.
12-11-2009, 03:54 AM
Adrian
Do you have a photo of the bars on your bike. Thanks
12-11-2009, 04:52 AM
Grand Prix 500 Favourite Bike: My 06 "60's" Scrambler
I have 34" wide trials bars with brace on, did it easy with a little re-routing.
FEAR - the best laxative.
12-11-2009, 06:39 AM
sprocket ,did the front brake line reach ok.
12-11-2009, 12:41 PM
Site Supporter SuperSport Favourite Bike: Bonnie Black Special
NH Western bars are 33" from tip to tip, the throttle cables work OK, but a longer clutch and brake hose are required.
12-11-2009, 01:24 PM
Front brake line no problem, however it is bonded in it's clamp on the fork so have you have to release that to get a little extra length.
Ian
