It's time to pull the plug - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-18-2009, 10:56 PM   #1 (permalink)
Favourite Bike: Mine
BlackandTan's Avatar
Other Motorcycle: Nope
So, I'm getting ready to store the bike for the winter (grumble grumble) and want to pull the spark plugs and put a few drops of oil in there. I've got an 09 Thruxton and it looks like I need to pull the tank to access the plugs. Any help would be much appreciated. Do I need to remove the tank to access the plugs? And if so, How do I remove the tank?
Or maybe I'll just follow the birds south for winter
BlackandTan is offline   Reply With Quote
Old 11-18-2009, 11:59 PM   #2 (permalink)
357Bob's Avatar
Going South sounds like the better choice. Remove the seat then remove the tank. It has a fuel line connected to the petcock & another line connected to a vent tube. Remove the tank bolts that you will see after removing the seat then pull the tank rearward to slid it off of the front bumpers. Also see who painted your tank. If you still have the air injection take it off too while you are there. There are kits sold to plug it off.
357Bob
Old 11-19-2009, 05:47 AM   #3 (permalink)
Favourite Bike: '71 Norton Commando
CommandoRdster's Avatar
Other Motorcycle: '07 Scrambler
Extra Motorcycle: '71 BSA Victor B50MX
You don't have to remove the tank to pull the plugs.
ANIMAL RESCUE SITE-Please go there and click on the purple button!
CommandoRdster is offline   Reply With Quote
Old 11-19-2009, 08:59 AM   #4 (permalink)
Favourite Bike: 2006 Thruxton
Of all the bikes and high performance cars I have ever owned which I have stored during the winter, I have never pulled the spark plugs and added oil to the cylinders.
1. Change oil and filter
2. Add Stabil to gas tank and run the bike until full operating temperature
3. Pull battery and place inside the house on a trickle charger
4. Cover bike (optional depending on garage conditions...covers can trap moisure wicking up from garage floor)
Do NOT start the bike during the winter months unless you are going to ride it for an hour. Ingession of water from cold air into the intake, cylinders and oil bath itself will do much more harm than good than intent of keeping the seals wet.
Hope that helps.
Thruxboy is offline   Reply With Quote
Old 11-19-2009, 01:16 PM   #5 (permalink)
caddyshack023's Avatar
Also, Check tire pressure and store bike on a stand, or just rotate tires every other week to avoid flat spots.
2006 Scram
caddyshack023 is offline   Reply With Quote
Old 11-19-2009, 02:10 PM   #6 (permalink)
Yup and a slight deviation from this as I don't like to put my bikes on a stand is place 2 X 6's under the tires and pump the tires to 50 lbs to minimize flat spotting. Never an issue with this approach. I like to get the tires off the concrete but not imperative either in my experience.
Probably time to pull the airbox off propforward Twins Technical Talk 10 10-31-2008 12:56 AM
Trick to pull center spark plug midliferider Hinckley Classic Triples 14 02-03-2008 12:34 PM
it's time to pull the AI on my thruxton runtheton Twins Technical Talk 2 01-19-2008 07:04 PM
Dyno Pull beatpusher Speed Triple Forum 4 05-26-2007 03:35 AM
snorkel, to pull or not to pull... opinions please (Bellmouth in hand) DJ Twins Talk 14 04-14-2006 07:48 PM
