11-18-2009, 08:48 AM
SuperStock Favourite Bike: 2005 bonnie black
valve adjustment
i know this is a important thing to do, especially on a new bike that has not had any adjustment, my concern is on a bike that has had the first adjustment done, how important are the adjustment later down the rode, i got 31,000 miles on my bike, put it in the shop to have it done and they want 325.00. said it is a 3.5 hour job. i know that shop time is different than regular time, i think. i don't mind paying for someone to do the work, but when is it going to be to much, i can do pretty good mechanical work, just not sure about this shim over bucket stuff. to bad there is not a class one could take to learn this type of work. not knocking a mechanic wanting to make a fair wage, but at 80.00 a hour, one has to try to save where he can.
2005 bonnie black, 790cc, sleeper exhaust, airbox cutup,unifilter pods , ai removed, green springs, gaiters, knee pads, mini tach, 157.5 mains,42 pilot jet,1.75 turns, thrux needles,progressive suspension front and back, marine corp emblem.
11-18-2009, 08:53 AM
Site Supporter Pole Position Favourite Bike: 98 Thunderbird
Posts: 4,097 Other Motorcycle: 03 Speedmaster
With a little knowledge you could at least check the clearances first, that way you don't have to pay if nothing needs doing.
11-18-2009, 09:08 AM
thanks for the reply, and you are correct, i started to check them and then said to myself if they are out i would still have to carry to the shop, i just rode it there, did have the extra valve cover gasket and bolt gasket. i will learn how to do the adjustment, it will take some time and need to purchase the correct tools to do the job.
11-18-2009, 09:43 AM
SuperSport Favourite Bike: MV 750 Sport 1972
Posts: 1,224 Other Motorcycle: tiger 1050 Extra Motorcycle: Moto Guzzi Falcone
 Doing your own valve adjustments isn't too dificult. Having a dealer nearby with a large and varied selection of shims, well that's much more unlikely, and explains why most folks take their bikes to the shop.
11-18-2009, 03:33 PM
Formula Extreme Favourite Bike: 07 Bonnie Black
Posts: 822 Other Motorcycle: 93 Yamaha GTS Extra Motorcycle: can't afford another
Do a search in the Technical Sticky, there are great step by step guides there. Also check your local Honda dealer for shims. The old CB750 / 900 & 1000 used the same shims, along with the Yamaha V-Max, V-Star. Honda had a whole tray with 10 shims of any size you would need.
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, Emgo 60's Cocktail Shakers, K&N Pods, ARKed 40/142, 1 shim, +1 risers, Custom gauge bracket, never ending tinkering
