Reluctant to go into 1st gear - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-11-2009, 03:02 PM   #1 (permalink)
Slinky's Avatar
I have noticed that sometimes, my 09 Bonneville does not want to go into 1st gear from neutral. I have to juggle the clutch and throttle whilst pushing on the gear lever. It has only happened a handful of times, twice today.
Anyone else experienced this?
The bike has 900 miles on it. Is this a typical symptom of a tight engine that gets better with more miles?
Old 11-11-2009, 03:32 PM   #2 (permalink)
Favourite Bike: two wheeled
grumpy_1944's Avatar
Other Motorcycle: Bonneville black
Extra Motorcycle: thumper
Start simple, get clutch adjustment checked.
Bill;
I took the road less traveled---------now where in the hell am I??
grumpy_1944 is offline   Reply With Quote
Old 11-11-2009, 03:58 PM   #3 (permalink)
Favourite Bike: My 09 Bonneville Black
Other Motorcycle: Want the new CB1100
Slinky, I occasionlly find the 1st gear a bit tight getting into and find that if you roll the back back or forward a foot she will go into the gear easier. You may have already picked up on that.
Ted.
LuckyBonnie is offline   Reply With Quote
Old 11-11-2009, 05:20 PM   #4 (permalink)
Shift into 2nd instead. Back down to neutral. Let out the clutch, pull in the clutch, shift into first.
Just got to get the gears lined up...
Like above, rocking will do it also (sometimes), this is doing the same thing, lining up the gears.
30942 is offline   Reply With Quote
Old 11-11-2009, 06:57 PM   #5 (permalink)
Favourite Bike: Thruxton
plodalong's Avatar
Other Motorcycle: Honda NSR150sp smokey
Sometimes it can be the Idle speed too high that causes a reluctance to go into 1st while stationary.
plodalong is offline   Reply With Quote
Old 11-11-2009, 07:58 PM   #6 (permalink)
+1 to what LuckyBonnie said. Usually a few inches back or forth works for me. Soon as you feel resitance on the clutch pedal, not going into first, start rolling a bit and it will drop right in place.
04Creamsicle is offline   Reply With Quote
Old 11-12-2009, 03:45 AM   #7 (permalink)
Slinky's Avatar
Thanks for the suggestions guys.
Cable adjustment is good, as is the idle speed.
I can understand having to line up the gear dogs, but this is a first for me- never experienced it on any other bike.
it always seems to happen when I'm at the head of a line of traffic at a red light
Having said that, I had no problems at all on my way in to work this morning so it is hopefully a rare occurence.
Old 11-12-2009, 08:44 AM   #8 (permalink)
Question 1st
Its still BRAND NEW!!!Give her a chance to get settled in like a few thou mi??
CAPT D
Old 11-12-2009, 09:18 AM   #9 (permalink)
Favourite Bike: 08 Rocket 3
KingOfFleece's Avatar
Other Motorcycle: Bonneville 2009
Had 4 new Triumph's and all have been that way and all get fine with a few miles on 'em.
KingOfFleece is offline   Reply With Quote
Old 11-12-2009, 10:10 AM   #10 (permalink)
Slinky's Avatar
That's good to know, I was hoping it would improve with a few more miles.
No 7th gear drakewn Daytona Deliberations 7 04-24-2008 11:35 AM
'02 955i / Wisconsin / Gear, gear, gear. wwpageiv Daytona Deliberations 2 06-07-2007 12:24 AM
Top Gear cornishgolfer1 Biker Hang-Out 17 02-15-2007 03:24 PM
"6th gear" Elim Twins Talk 10 01-15-2006 12:10 PM
Reluctant triple drainbamage Speed Triple Forum 11 08-05-2005 02:21 PM
