Have been thinking around your question... not claiming to have any answer, but heres my thoughts....
Regarding heating the sump (oil) - i guess some sort of cartridge heater through the sump into the oil would be the ultimate, but serious work involved there i think.... and then i ask but what would it really achieve (in liveable temperatures).. because i'm thinking if i used say a 5/40w oil as opposed to a say 10/40w or a 15/50w then i probably achieve as much with that 5/40 as i would with the heater in a 15/50, so could i perhaps achieve the same by coosing a different oil grade ? (perhaps i'm wrong - others will have more knowledge than me on this subject).
Anyway it led to my further thoughts and that is...
If i parked outside under plastic what would be the best i could achieve - park out of the wind (avoid wind chill like being garaged) - park against a wall - one that stands during the day in whatever sun there is available - great if wall is brick or concrete (absorbs heat from sun) - if my wall can i paint it black? (absorb more heat) - can i arrange ground i park on to be similar (concrete/ black/ in sun during day) - and then lastly rather than a throw on cover, could i fix timber frame to wall and mount cover to that timber (in effect mini plastic garage). If i could then leave cover open during day - let walls absorb from sun - close up at night - and Bonnie has its own storage heater in shelter if i can keep the wind out.
Best of luck however you go about it.
Regards,
GrnBon
Triumph Twenty One - 3TA - 350cc.
1957/1966 - Police Motorcycle - bathtub enclosure.
