I ride my Bonny pretty hard, and lately I have been having problems with ground clearance on the left side in left hand corners.
I've found that the side stand is scraping on the road, not just the foot part, but the whole length of the stand and the mounting ...
Now I don't want to throw her up the road and scratch her up, so i've had to adjust the rear shocks up a notch on the spring pre-load position in an effort to keep from scraping the stand, but running the shock like this makes me get bounced off the seat on some bumps.
The obvious solution is to back off a bit in the corners, but when you are racing through the twisties with your mates, backing off is the last thing you want to do...
I don't think I can do without the side stand on the bike, as the new Bonny doesn't come with a center stand. Anyone else have this same problem with ground clearance, and if so, what did you do about it?
Thanks,
S.
