Torque Wrench Purchase Advice - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Honda Powersports New BonnevilleMotorcycle.comSportbikeTrackGear
Old 11-04-2009, 06:50 PM   #1 (permalink)
Favourite Bike: Thruxton
casino's Avatar
Hi Guys, I'm going to attempt the flip and swap clip ons mod on my 05 Thrux. Basically all the work I've done on the bike so far has just been by feel when tightening. But I figure the handle bars are such a crucial part of the bike, I don't want to get it wrong or damage anything. So I figure nows as good a time as ever. I've never used one before and obviously never purchased one either. Can anyone offer some advice? I think on the clip ons there are allen bolts, and I'll also need to take off the top yoke –*will one wrench suit a variety of applications? I've got the various torque settings (thanks to this forum!) that I need to do the swap, but just no idea how to apply these either, hopefully it will make more sense when i have the wrench in my hand!
Cheers
casino is offline   Reply With Quote
Old 11-04-2009, 07:01 PM   #2 (permalink)
Favourite Bike: 2008 Bonnie T100
bonza's Avatar
I see you are in Sydney Australia, so I recommend you visit this
http://www.warrenandbrown.com.au/Pre...FQEupAodaAOUyA
or
http://www.norbar.com.au/
they make a good range of different sizes here in Aussie. I have used them a lot
I'm a spanner man/mech engineer by trade and profession, and if there is one thing I have learnt, buyin a cheapo torque wrench is not only inaccurate, but a complete waste of time and money
a 3/8" drive 0 - 80 Ft/lb range should suit most bike applications
2008 Black and White T100.
AI removed, Bafflectomy, 40/115/1 shim 2.75 turns, Pingel fuel valve, Monza petrol cap, Avon Roadriders, Triumph fabric saddle bags sometimes
I like a man who grins when he fights -
Winston Churchill
bonza is offline   Reply With Quote
Old 11-04-2009, 07:55 PM   #3 (permalink)
Favourite Bike: 07 Thruxton "Ava"
blackstar1965's Avatar
Other Motorcycle: BSA B44 Victor Special
Extra Motorcycle: 06 Ducati PS1000LE
While I agree with Bonza about cheap torque wrenches, I don't think you need to spend a large sum of money on a torque wrench, as you really aren't going to use it as often as you think.
The reality is, you aren't going to take off any bolts/nuts with a torque wrench, so you're only going to use it for half the job anyway.
Also, being that you're not a mechanic and you're not going to use it even once a week, it's going to collect dust after you use it for this project; so if you forget to back it off and then don't touch it for a couple weeks/months, it already has to be recalibrated and won't be accurate next time you want to use it.
Don't buy the cheapest one you see, and don't buy the most expensive.
Also, make sure the wrench has a Newton-Meter (Nm) scale on it.
That's handy.
"So many people take the gift of communication for granted. Just shut up for once." - Me (as far as I'm concerned)
blackstar1965 is offline   Reply With Quote
Old 11-04-2009, 08:02 PM   #4 (permalink)
casino's Avatar
thanks guys, great advice so far.. All the settings in the haynes manual are in NM so that is crucial..
Old 11-04-2009, 09:24 PM   #5 (permalink)
Favourite Bike: 05 Black Speedmaster
Unless you are in the engine and you have the "feel" you are better off without a torque wrench. Most of the stripped thread problems listed here are done WITH a torque wrench.
Old 11-04-2009, 09:42 PM   #6 (permalink)
casino's Avatar
Really? I just thought since i was removing the top yoke and clip ons it would be so crucial to get it right.. The large bolt on the top yoke (hope I'm using the right terminology here) seems pretty important! I don't want it flying off or being done up too tight and not doing it's job properly..
Old 11-04-2009, 11:43 PM   #7 (permalink)
I didn't think you had to remove that nut...
I thought the pinch bolts on the yokes and clip-ons were were loosened, controls removed, forks lowered, bars swapped, and then put back together.
Someone correct me, I haven't done the mod myself.
I agree with Normandy, but for someone that hasn't done much wrenching, a torque wrench will help them learn the feel.
I rarely use a torque wrench at work and I doubt the bike was put together with one...
Old 11-04-2009, 11:52 PM   #8 (permalink)
casino's Avatar
I think there are two ways to do it (from researching), one requiring a bike lift, the other taking the top off?
Old 11-05-2009, 12:35 AM   #9 (permalink)
plodalong's Avatar
Other Motorcycle: Honda NSR150sp smokey
Have to agree with Bonza, Warren and Brown arn't cheap but they're very accurate and don,t go out of calibration easily like some of the breaker type. I used to work in an aviation calibration centre and even the good quality ones like snapon, norbar ect go out of calibration quickly if the setting isn't backed off after use and we all forget sometimes. Another point is you have to hold the torque wrench in the right place usally marked on the handle or your torque wont be right. You will also need a 30mm socket for that big nut on the top yoke (its a lot easier than dropping the forks) I also err on the low side of the torque value if the bolts threaded into alloy as i've seen a lot of stripped threads.
plodalong is offline   Reply With Quote
Old 11-05-2009, 11:58 AM   #10 (permalink)
Favourite Bike: 08 T-100 Claret & Silver
Overkill0084's Avatar
Other Motorcycle: TBD
If there is a problem with breakage when using a torque wrench, then there is at least one problem, possibly 2.
1. Operator error
2. Defective/poorly engineered parts.
I have seen the product of people who did it by feel:
Missile and launcher lost in flight because of inadequately torqued mount bolts. The F-16 wingtip launcher is held by only 3 bolts torqued to 1000 in/lbs, you really want to get that right. Person thought that "gutentight" was enough.
While there are some out there who can nail a proper torque by feel, most can't. I really don't want to risk my life/bike etc. on it. It's only 30 more seconds of the job, why shortcut it? How about head bolts, do you really want your mechanic guessing. How about the guy at the tire shop? I always watch the wheel install to ensure they torque the lug nuts, am I the only one? 2 grunts is not a torque spec.
Cheers,
Greg
2010 Thunderbird SE
Overkill0084 is offline   Reply With Quote
torque wrench? Striple Street Triple Forum 7 04-01-2008 09:29 AM
Torque Wrench decobike Twins Talk 20 07-09-2007 06:13 PM
torque wrench CCR Maintenance & Workshop Talk 11 06-03-2007 09:12 PM
Torque wrench doctorjay Twins Technical Talk 22 03-07-2007 09:20 PM
torque wrench ? Colonel_Dorkus Twins Talk 10 05-28-2006 03:14 PM
