When is rejetting needed? Signs? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-04-2009, 09:02 AM   #1 (permalink)
caddyshack023's Avatar
Im new to the Scrambler scene...so here is the scoop:
I have a 06 Scrambler, only performance mods done are the de baffled mufflers and AI removed. Cold start I need the choke half way, then quarter way for about 4 min before it can idle on its own. My question is, do I need to rejet? If im running too lean will it hurt in the long run? Im at about 500 ft above sea level for tech. detail.
2006 Scram
caddyshack023 is offline   Reply With Quote
Old 11-04-2009, 09:17 AM   #2 (permalink)
Favourite Bike: 07 Bonnie Black
Derby Boy's Avatar
Other Motorcycle: 93 Yamaha GTS
Extra Motorcycle: can't afford another
I guess it would help to know the history of the bike. You say it was de-baffled. I assume this was by the previous owner, if so then do you know if he/she rejetted? The next thing is does it feel like it's not running right? I'm more familiar with the 360° bonnies. If it's really bugging you take it to a good tuner an have the air/fuel ratio tested throughout it's range. The tuner should be able to tell you if it needs to be rejetted. One of the seat of the pants test is to get up to 65-70 mph then WOT to about 80-90 then back off the gas a little. If it seems to accelerate a little when you back off then you may be running a little lean. I've never felt this phenomenom but heard it works.
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, Emgo 60's Cocktail Shakers, K&N Pods, ARKed 40/142, 1 shim, +1 risers, Custom gauge bracket, never ending tinkering
Derby Boy is offline   Reply With Quote
Old 11-04-2009, 11:15 AM   #3 (permalink)
No I did the de baffle myself, I purchased it with 700 miles. I have had it WOT at 90, but really wasnt paying attention to the throttle position vs. acceleration, taking it somewhere would be a good thing but I think it should be ok as is. Thanks.
2006 Scram
Old 11-04-2009, 11:46 AM   #4 (permalink)
Derby Boy's Avatar
Well if you de-baffled it and everything else is stock it would probably help to go up a few sizes in main jets. The Twin line is notoriously lean from the factory. When I de-baffled my bonnie and removed the snorkel, I went from 110 mains up to 115's and added a .5mm shim under the needle. The bike ran better and it got rid of the flat spot @ 45-50 mph in 5th. Do a search on jetting on this forum, there is tons of info for almost every set up.
Old 11-04-2009, 12:01 PM   #5 (permalink)
Favourite Bike: 08 T-100 Claret & Silver
Overkill0084's Avatar
Other Motorcycle: TBD
You're still on break in, it only gets better. Has anything been done to the intake side? Snorkel removal, UNI filter, etc?
I think Derby Boy is pretty close to the mark on settings. I would add a 1/4 to 1/2 turn on the pilots. It should help the startup. If you haven't done the snorkel removal and stuck in a high flow filter, you might as well. Then jet it up and enjoy.
Cheers,
Greg
2010 Thunderbird SE
Overkill0084 is offline   Reply With Quote
Old 11-04-2009, 12:38 PM   #6 (permalink)
Favourite Bike: Bonnie Black Special
PieMan's Avatar
If you've only de-baffled, leave the jetting as standard. No need to rejet until you work on the inlet.
Mike (UK)
04 Bonnie Black
PieMan is offline   Reply With Quote
Wat Or The Signs Of Bad Coils?? cad4kad Trophy 3 02-20-2009 08:18 PM
signs of a recession? retrobiker Classic, Vintage & Veteran 1 04-07-2008 10:49 AM
A Lurker Signs On eeyore Twins Technical Talk 17 08-28-2007 11:48 PM
Are there too many warning signs ? Tbirdnz Biker Hang-Out 13 08-21-2007 05:49 PM
Reading the signs beatpusher Speed Triple Forum 13 06-23-2006 01:33 PM
