False Neutrals - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-03-2009, 06:04 PM   #1 (permalink)
Favourite Bike: 2010 Scrambler
Dog Trainer's Avatar
False Neutrals
Have a 2010 Scrambler for one week. 200 miles on it. My first Triumph in 43 years of motorcycles. Loving it but I sometimes get false neutrals when down shifting from fourth to third and third to second. Is this common? Will it improve when I drain the breakin oil and replace with 4T?
Thanks,
Larry
Dog Trainer is offline   Reply With Quote
Old 11-03-2009, 08:47 PM   #2 (permalink)
Favourite Bike: Thruxton
plodalong's Avatar
Other Motorcycle: Honda NSR150sp smokey
Ive never had a false nuetral on my thruxton, but it had done 2k when I got it. Could be technique , possibly clutch or shift lever adjustment (is the shift lever position adjustable on a scrambler?) If it dosn't improve get the dealer to look at it at service time.
plodalong is offline   Reply With Quote
Old 11-03-2009, 09:33 PM   #3 (permalink)
Favourite Bike: 2007 Thruxton
sbpark's Avatar
try adjusting the clutch cable. since the bike is new the clutch cable will stretch a bit in the first 500 miles. so will the throttle cable.
'07 Thruxton, Caspian Blue Checker, FCR's, 813 cams, Pieman ignitor, Predators, ported & polished head...
sbpark is offline   Reply With Quote
Old 11-03-2009, 10:23 PM   #4 (permalink)
Favourite Bike: 09 Bonnie Black
Toonces's Avatar
Other Motorcycle: really?
Umm....what break in oil? mine had 4T in it from the start.....and that was an '07....
maybe not enough omph when shifting...just say'n...
http://www.youtube.com/watch?v=u_WXxYGyRas
Noli Irritate Leones: Toonces
Toonces is offline   Reply With Quote
Old 11-04-2009, 12:16 AM   #5 (permalink)
sbpark's Avatar
i'm pretty sure they dont have Mobil1 4T oil in from the factory. if i recall correctly is a different type of (possibly conventional) oil for the first 500 miles?
Old 11-04-2009, 09:51 AM   #6 (permalink)
Yeah, that's my understanding also. Got to thinking about my false neutrals and realized it didn't happen in the first hundred miles. Adjusted the clutch cable last night. We'll see if it helps.
Larry
Old 11-04-2009, 11:55 AM   #7 (permalink)
Favourite Bike: 07 Bonnie Black
Derby Boy's Avatar
Other Motorcycle: 93 Yamaha GTS
Extra Motorcycle: can't afford another
I've had my 07 bonnie for almost 18K miles since brand new and never found a false nuetral. These bike have such a positive shift that I don't think I could find one if I tried. If this persists you should see your dealer as something may be wrong in the shift linkage in the tranny. Try being more positive with your shifts, I've shifted with and without the clutch and it's always positive. I don't think a clutch adjustment will change anything.
As for the oil, I'm pretty sure that all motorcycle oil is 4T as it designates wet clutch use. The factory oil is usually a dino oil that is put in for breakin. At the 500 mi. service it's changed to Mobil 1 synthetic or equivelant.
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, Emgo 60's Cocktail Shakers, K&N Pods, ARKed 40/142, 1 shim, +1 risers, Custom gauge bracket, never ending tinkering
Derby Boy is offline   Reply With Quote
Old 11-04-2009, 06:12 PM   #8 (permalink)
Adjusted the clutch cable, repositioned the shift lever. 45 mile ride today with no false neutrals. Thanks for the suggestions guys. Sometimes it helps to be reminded of the obvious.
Larry
False Neutrals on '08 Speed Triple Bandala Speed Triple Forum 13 02-20-2009 01:54 AM
Anyone get false neutrals riron2001 Twins Technical Talk 13 07-13-2007 06:23 PM
False neutrals Snotrocket Speed Triple Forum 14 04-26-2007 05:03 PM
False Neutrals? xsubsalior Twins Technical Talk 12 10-17-2006 09:01 PM
false neutrals 97TB Speed Triple Forum 5 10-27-2004 02:27 PM
