replacing stock 2008 thruxton clutch lever with same - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismSportbikeTrackGearHonda PowersportsMotorcycle.com Classifieds!
Old 11-03-2009, 05:38 PM   #1 (permalink)
Favourite Bike: 2008 Chromium Thruxton
theblackhand's Avatar
This is my first bike with a cable clutch and my lever snapped off (don't ask) and I searched the threads but couldn't come up with any answers that fit (and I don't have a shop manual cause I don't have a shop). When the new lever arrives I obviously can figure out how to take the remainder of the bar screwed to the handlebar out and try to not to lose any of those little springs. My questions is, do I need to loosen the screws that are attached to the clutch cover to get enough free play in the cable to remove what's lever of the lever? If this is the case, does just tightening the same screws by the clutch cover re-tighten the cable or is there some little trick here to make sure I get the free play in the right range. Thanks.
theblackhand is offline   Reply With Quote
Old 11-03-2009, 08:22 PM   #2 (permalink)
Favourite Bike: 2007 Thruxton
sbpark's Avatar
you dont have to loosen/remove the bolts on the clutch cover. if you have to remove the cable you just need to loosen the two nuts that tighten the clutch cable onto the piece that bolts onto the clutch cover (if that makes any sense). no messing with clutch cover bolts required.
'07 Thruxton, Caspian Blue Checker, FCR's, 813 cams, Pieman ignitor, Predators, ported & polished head...
sbpark is offline   Reply With Quote
Old 11-03-2009, 08:23 PM   #3 (permalink)
Favourite Bike: 2005 Bonneville Blue 790
Yes, assuming you mean the two nuts securing the bottom end of the cable; nothing else needs to be loosened down there. Loosening it at the bottom makes it easy to swivel the cable around and take it out at the lever, and it's not a problem.
Assuming that you know how to adjust the clutch cable, attach the cable at both ends, screw the top end almost all the way in, then use the bottom end to take up most of the slack, then gently tighten the nuts, and make your final small adjustment at the top.
It's easy, and if you don't get it right, just loosen at the bottom and adjust some more. As long as you're in the ballpark, the fine tuning can be done at the lever end.
Marty
Baltobonneville is online now   Reply With Quote
Old 11-04-2009, 10:09 AM   #4 (permalink)
Thanks fellas.
Old 11-04-2009, 02:31 PM   #5 (permalink)
Get a cable luber kit (with the little gadget and a can of aerosol cable lubricant) and squirt some oil in the cable while you have it off.
Marty
'09 Thruxton won't start after replacing broken clutch lever man_in_black Twins Technical Talk 6 04-26-2009 07:37 PM
Replacing bent break lever. SMF77 Maintenance & Workshop Talk 3 03-22-2009 06:03 PM
Does anyone have a stock clutch lever that they can part with? jcline8 Twins Technical Talk 1 08-19-2007 02:29 PM
Replacing footpegs, fixing gear lever on Trident WhoWantsTrident T3 Sport / Touring Forum 3 05-21-2007 02:46 PM
