air box / pod filters do I have to remove the air box - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Motorcycle.comOntario TourismHonda Powersports
Old 10-15-2009, 08:42 PM   #1 (permalink)
Do I have to remove the air box in order to use pods . I thought there was a way around it . I did a search to no avail .
oh on a 07 scrambler
going to do the following to it
12 inch shorties which I have
air box I would like to find a way around it
and AI i'll get
Will be installing bonneville pipes on it with the shorties.
As I have bags that will work for the winter with the low pipes .
Then back to high pipes in the spring
Dr mac is offline   Reply With Quote
Old 10-15-2009, 09:05 PM   #2 (permalink)
Favourite Bike: 2006 Thruxton Caspian Blu
ocguyocguy's Avatar
Other Motorcycle: H.D. and Honda
Extra Motorcycle: MX, off road, Enduro
You really need to cut the airbox to fit pods...they won't fit without cutting. I did this it works great and you really need to remove box from bike to cut properly. You might be able to do it on the bike but too much hassel..DO LOOK at the threads here on cutting the airbox...so easy by the pictures...cut so your mounting points for all the dodads are still there. LOOK AT THREAT PHOTOS...STEP BY STEP...
ocguyocguy is offline   Reply With Quote
Old 10-16-2009, 03:23 AM   #3 (permalink)
Favourite Bike: Can't decide now!!
Ventura's Avatar
Other Motorcycle: Scram + Thrux
Extra Motorcycle: '71 BSA Thunderbolt
The choices with your airbox are numerous.
To fit pods you'll either have to hack it or remove it.
And everything you'll likely need to know how is in this sticky..................
http://www.triumphrat.net/1132928-post8.html
Airbox Removal
Hints and Suggestions on the Practicalities of Airbox Removal
Pictures of What's Involved
Frank Blacks Home Made ARK (FARK) excellent!
mr badda bings Home Made ARK (HARK)
markbvt's Airbox Removal (MARK)
blackjacks Airbox Removal (BARK)
Airbox Modification by keef (KARK)
Airbox modification with great pictures
Reflections on Airbox Removal and Predator Install
Basics of Airbox Removal using a purchased ARK
ARK installation by Yellowrubiu
Wind turbulence affecting carburation
Should You Even Do It?
Further thoughts on benefits and otherwise of the airbox and its removal
What's the Best Airbox Removal Kit?
Airbox Modification
Scrambler Airbox Mod - Part 1 (Ventura)
Scrambler Airbox Mod - Part 2 (JohnyC)
Scrambler Airbox Mod - Part 3 (Ventura)
Velocity Stacks in the Airbox
Pictures of Airbox Gutting
EFI bike airbox mods
I'm sure something in that lot will help!
V.
2006 Scrambler, VARK'd, 155/40, 790 In-cam, Pieman'd igniter, DNA Pods, Zard 2:1.
2005 Thruxton, Black now, with ARK, FCR 39's & Uni's, Retimed 790 cams, Barnett clutch and suchlike!!
Ventura is online now   Reply With Quote
Why Remove AI azrat Twins Technical Talk 23 02-20-2008 03:16 PM
How Do I Remove The Fuse Box? alienbeing Speed Triple Forum 4 08-03-2006 10:28 AM
How to remove DoctorW Speed Triple Forum 3 05-15-2006 11:46 AM
To remove or not to remove? 95bravo Twins Talk 19 03-08-2006 01:55 AM
Remove airbox, install K&N Cone filters Maintenance & Workshop Talk 1 03-06-2003 03:58 PM
