here's a dumb question, how does the rev limiter work? - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 17 (permalink) Old 09-16-2009, 03:55 PM Thread Starter
Main Motorcycle: '06 Thruxton
neuroboy74's Avatar
Other Motorcycle: it has pedals.
i have a carbed bonneville. i think i works by identifying the electrical impulses coming from the engine, but that's the extent of my knowledge.
http://img177.imageshack.us/img177/2076/homestarqa6.gif
neuroboy74 is offline
post #2 of 17 (permalink) Old 09-16-2009, 04:02 PM
Forchetto's Avatar
On carburetted models it interrupts the signal to the coil, probably alternating on/off, slowing the firing sequence.
On EFI models I think it cuts the signal to the injectors.
Pieman will know for sure. He mods igniter units before breakfast.
Forchetto is offline
post #3 of 17 (permalink) Old 09-17-2009, 01:14 AM
Someone else posted elsewhere that the ignition control unit drives the tachometer. If so, it knows how fast the engine is spinning and can cut the signal to the coil when it hits the limit. I doubt it's any more complicated than that.
Which makes me wonder how the ignition control unit knows the engine speed, as opposed to just knowing to send a spark at certain points in the engine cycle, as points used to do.
Marty
Baltobonneville is online now
post #4 of 17 (permalink) Old 09-17-2009, 10:03 PM
Main Motorcycle: '03 T-100 & '08Tiger1050
Because it's a computer, and it is fed enough data to calculate rpm easily.......Crank Position Sensor inputs to the Igniter on the older ones and I suppose the EFI bikes call this the ECU or whatever. The rev limiter is probably just a value in a read only register that the computer uses for input.
Larry
RedBird is offline
post #5 of 17 (permalink) Old 09-17-2009, 10:42 PM
Main Motorcycle: '08 Moto Guzzi 1200 Sport
ohiorider's Avatar
Other Motorcycle: 2012 Griso - SOLD
Extra Motorcycle: 1991 BMW R100GS
Older Beemers like my first (K100RS - 1985 model) used Bosch LE Jetronic .... as it approached red line, it first retarded the spark, which slowed things down a bit. If the rider insisted on keeping the revs rising, next the Bosch system cut off the fuel injection system. No fuel = no go!
Like Larry said, it's digital. All the ECU is looking for is whether the rpm is less than, same as, or greater than a redline value loaded into it. Like other computer decisions. Think it's based on Boolean logic.
Bob
GBNF: 03 T100 Luc Org and Silv: 122/42 jets, TORs, 18T, UNI filter, no AI, Polaris bellmouth, Metz 880 tires, Prog. 440 shocks (105/150 springs), 11-1124 frk springs, Thrux frk caps, gaiters, MotoTwin bars, 6024 lamp, htd grips, 12v outlet.
ohiorider is offline
post #6 of 17 (permalink) Old 09-18-2009, 12:58 AM
Main Motorcycle: 07 Bonnie Black
Derby Boy's Avatar
Other Motorcycle: 2012 NC700X
Extra Motorcycle: 81 CB750C
I found out first hand last week while playing with my buddy on his Yami custom Warrior (that thing eats my lunch). Took first gear a little too far, when it hit the limiter it was like you turned off the key. I backed off hit 2nd at it was firing like a dream. It's the first time I've hit it in 16,000 mi., whish I had of been whatching the Tach but I was busy trying to dust him in vain.
"Another Trumpet Rat enslaved to a Bonnie"
07 B/B, AI gone, Emgo 60's Cocktail Shakers, K&N Pods, ARKed 40/142, 1 shim, +1 risers, Custom gauge bracket, never ending tinkering
Derby Boy is offline
post #7 of 17 (permalink) Old 09-18-2009, 02:58 AM
Legend
Main Motorcycle: 904cc Bonnie w/magwheels
sweatmachine's Avatar
Send a message via AIM to sweatmachine
wow, I hit my rev limiter several times on every ride
sweatmachine is offline
post #8 of 17 (permalink) Old 09-18-2009, 09:17 AM
There must a clock or timing register to get the rpms.
Marty
post #9 of 17 (permalink) Old 09-18-2009, 09:52 AM
Main Motorcycle: 05 speedmaster - black
Other Motorcycle: 2010 Thunderbird - silver
Extra Motorcycle: 2014 thruxton - black
perhaps you should consider shifting up ! those highway speeds in first are he#l.
see my wicked black speedmaster
904cc, 12:1 JE racing pistons, thunderbike cams, ported and polished head, scepter pipes, 39mm FCRs.
mag10 is offline
post #10 of 17 (permalink) Old 09-18-2009, 01:21 PM
Derby Boy's Avatar
S.M. ; you're an animal
Dumb Question: Rev Limiter on Speedmaster? sbaker33 Twins Technical Talk 17 04-01-2009 05:52 PM
Dumb Question DrewDesign007 Twins Technical Talk 5 09-21-2007 03:56 PM
Dumb question..... Doc007 Speed Triple Forum 17 03-17-2007 04:56 AM
Rev Limiter Question JubileeBonne Twins Talk 51 07-21-2005 02:00 PM
the rev limiter question...........again!! ajdaytona900 Daytona Deliberations 4 06-30-2005 01:55 AM
