41mm headlight brackets - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!New BonnevilleMotorcycle.com
Old 07-14-2009, 02:00 PM   #1 (permalink)
Favourite Bike: '05 Triumph Bonneville
Craigore's Avatar
Other Motorcycle: '51 Harley Panhead
Extra Motorcycle: '79 Harley Ironhead
Looking to lower my headlight assembly and eventually transition into clip-on bars... not crazy about the options given to us by the regular vendors (which, for my tastes and budget are too ugly and/or expensive). In a perfect world, I'd also mount my mini turn signals from them.
Found these: http://www.xpostreetfighter.com/detail.aspx?ID=68 which might work.
Anyone have any experience in this? If so, post your findings!
Craigore is offline   Reply With Quote
Old 07-14-2009, 07:18 PM   #2 (permalink)
Favourite Bike: 2007 Triumph Thruxton
blight's Avatar
Other Motorcycle: 2010 Harley XR1200
Extra Motorcycle: 1969 BSA 441 Victor
Found these: http://www.xpostreetfighter.com/detail.aspx?ID=68 which might work. Anyone have any experience in this? If so, post your findings!
I got these universal Ceriani style alloy ones on ebay. They are made for 41mm forks, (but have adapters for smaller) and are a brushed aluminum alloy that you could also polish out or paint. I left them brushed alloy and they match the Thruxton bits nicely.
They are also shorter out to the headlight bolts by about 1" so it brings the headlight bucket back neatly. You can then adjust the height up and down on the fork tubes to suit by several inches.
I also drilled them and mounted turn signals to them. Here's a pic: (I hope you don't think these are the ugly ones!!)
Cheers,
BLIGHT
blight is offline   Reply With Quote
Old 07-14-2009, 07:27 PM   #3 (permalink)
blight's Avatar
Oh, and if you like the brackets, here is a new set on ebay:
http://cgi.ebay.com/ebaymotors/Alumi...86Q2ec0Q2em14Q
Cheers,
BLIGHT
Old 07-14-2009, 07:30 PM   #4 (permalink)
blight's Avatar
Cheers,
BLIGHT
Sorry, I accidentally chopped the link...this should work:
http://cgi.ebay.com/ebaymotors/Alumi...ht_3489wt_1149
BLIGHT
Old 07-14-2009, 08:18 PM   #5 (permalink)
Craigore's Avatar
Red face
Yeah that looked pretty good and inexpensive also. I'd probably powder coat also. Anyone else???
Old 07-15-2009, 03:36 PM   #6 (permalink)
Favourite Bike: 03 T100
mikeinva's Avatar
I put joker machine mounts on mine there not cheap but I like them
Old 07-15-2009, 03:49 PM   #7 (permalink)
Retro-Racer's Avatar
Yeah Mike, those Joker brackets are the business. Have you seen the new clutch cable bracket and EFI T/B Tops? Trick stuff.
/M
Retro-Racer is offline   Reply With Quote
Old 10-27-2010, 11:05 AM   #8 (permalink)
Favourite Bike: 2009 Bonneville T100
Mr_Toad's Avatar
Other Motorcycle: 1997 Adventurer 900
updating location where to buy the universal Ceriani style alloy ones
http://store01.prostores.com/servlet...adlight/Detail
He once owned a Harley Davidson and a Triumph Bonneville. Counted his friends in burned-out spark plugs and prays that he always will.
~Jethro Tull (too old to rock n roll, too young to die)
Mr_Toad is offline   Reply With Quote
Old 10-27-2010, 11:53 AM   #9 (permalink)
Favourite Bike: 2004 Thruxton
Other Motorcycle: 1971 BMW R50/5
Extra Motorcycle: 1971 CB350
No experience with those, but I can't see how the single bolt anchor would hold the headlight over bumps...
I've got LSL headlight mounts...they're the early version with headlight mounts cast into the lower strut. Prior to springing for those, I used some CB750 exhaust clamps on the fork tubes to connect the stock thruxton headlight mounts.
Good luck,
--Rich
beemerrich is offline   Reply With Quote
LSL Headlight Brackets fit on 41mm forks? Tanguma Twins Technical Talk 7 06-28-2007 06:42 PM
Installation of Headlight brackets 5bassman Twins Technical Talk 2 11-07-2006 10:50 AM
Headlight Brackets.... kwajazz Club Cafe' 13 03-02-2006 10:23 PM
Headlight Brackets Mancha Club Cafe' 2 05-06-2005 01:43 PM
