Fork spacer question - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearHonda PowersportsMotorcycle.com Classifieds!
Old 07-13-2009, 06:01 PM   #1 (permalink)
Just got my intiminators delievered and about to start the install. Question is for the few here using pvc pipe as spacers. What size and type are you using? I plan on going this route for the ease of cutting over the steel spacers, plus might be lighter. Another is I have some sitting around the house. I have a bonnie without the thruxton caps. I'm also thinking I can play with different lengths to adjust preload.
meister is offline   Reply With Quote
Old 07-13-2009, 07:45 PM   #2 (permalink)
Favourite Bike: 2003 T100
ohiorider's Avatar
Of course, the piece of scrap that's left has no markings on it, but it mikes out as follows:
OD - 33.45mm/1.315"
Wall thickness - 3.65mm/.143"
Could be off a fraction of a mm or so on the OD and wall thickness, but this should be close enough for government work!
Bob
Old 07-13-2009, 08:20 PM   #3 (permalink)
Favourite Bike: '06 T100
road dog's Avatar
1" schedule-40 PVC pipe... just like Bob's dimensions.
-Phil
road dog is offline   Reply With Quote
Old 07-13-2009, 08:27 PM   #4 (permalink)
Thanks for the help. Now to start the work.
axle spacer help please NJTiger Classic, Vintage & Veteran 13 06-23-2009 06:20 AM
spacer orientation question '69 T100S NHOJ from Maine Classic, Vintage & Veteran 5 08-06-2008 09:14 PM
Fork Spring Spacer question? Buckwheat T3 Sport / Touring Forum 6 04-13-2008 11:57 PM
Quick Wheel Spacer Question Goldendog Twins Technical Talk 23 08-19-2007 06:36 PM
Installing Ikon progressive fork springs - Spacer? ivar Twins Technical Talk 10 06-15-2007 08:24 AM
