19 Tooth Front Sprocket Chain Issue - Triumph Forum: Triumph Rat Motorcycle Forums
New BonnevilleSportbikeTrackGearOntario Tourism
Old 07-12-2009, 10:44 PM   #1 (permalink)
Favourite Bike: 2007 Triumph Thruxton 900
Other Motorcycle: 2005 Kawasaki Vulcan 1600
Hi all,
I know the 19 tooth topic has been covered here ad nauseum, but I didn't see my particular issue covered here.
Of all the threads I read regarding the benefit of swapping out the front sprocket to a 19T was that it was an easy like 20 minute job. Not so for me.
I was under the impression that I could get away with the swap without having to do any chain slackening, obviously I was mistaken.
Anyway, reading my Haynes manual says I need to "slaken" the axel bolts then adjust the chain adjust screws. Well I have three issues:
1. Which way do those axle bolts loosen to come off? They must have been put on by a gorilla because I can not seam to break them loose and I am not exactly sure I am trying to loosen them in the right direction! Can't find it covered either in Haynes or in my owners manual. Feel kinda stupid here but I'm afraid of stripping or worse breaking a bolt off!
2. Once I have the axle bolts loosened, then I need to adjust the chain tensioner screws inward, on BOTH sides EQUALLY in order to slacken the chain right, or am I missing something?
3. Also, on my 07 Thrux the right side axle nut is larger, maybe 21 mm than the left side nut which is definitely 19 mm, is this normal or did the owner before me possibly change out the right side for some reason? Now I need to get a 20 0r 21 or 22 mm socket. Anyone know for sure why the nut sizes would be different?
To make matters worse, I'm not totally convinced I'm going to like the 19 tooth but I bought it from Brent from New Bonneville and figure I have to at least give it a go. Thought this process was supposed to be easy..I spent the whole afternoon trying to get this done to now avail!
Any help, insight and clarity would be greatly appreciated.
Thanks all!
Rob
British Custom Predators - Air Box Removal
Fender Eliminator Kit -19 Tooth Front Sprocket
Ikon Rear Shocks - Superbright LED's
Tridentnyc is offline   Reply With Quote
Old 07-12-2009, 10:51 PM   #2 (permalink)
Other Motorcycle: SV1000s
Unfortunately I can not help you with your problems but I would be very interested in the replies you get. I have Triumph Sprint and I will be looking to go down from my (stock) 19T to your (I am assuming) stock 18T..... Do you still have your stock 18T front sprocket?
dmac is offline   Reply With Quote
Old 07-12-2009, 10:54 PM   #3 (permalink)
I do still have it yes, I'll be holding on to it until I can determine whether I like the 19T or not...that is if I can ever get it installed!
Old 07-12-2009, 11:03 PM   #4 (permalink)
Favourite Bike: 04 Bonnie black
The axle is 19mm,the nut is 24mm.They loosen like normal,clockwise to tighten,counterclockwise to loosen. Loosen the nut a good bit,loosen the adjusters all the way and push the wheel forward,install the chain and re-adjust the chain,tighten the axle.. Remember,don`t loosen the chain until you have broken the 36mm nut loose on the CS sprocket.You need the chain on to use the brake to loosen the big nut.
rodburner is online now   Reply With Quote
Old 07-12-2009, 11:15 PM   #5 (permalink)
Thanks Burner! Just a couple more questions:
Am I loosening both axle nuts or only the 24mm right side one? Again, I have a 19mm nut on the left side..not sure if that is stock or not.
My Haynes manual only shows a pic of the right side 24mm bolt being loosened, is it possible I only need to loosen that bolt in order to move the wheel up?
Thanks again Burner...sorry for all the dumb questions!
Rob
Old 07-12-2009, 11:22 PM   #6 (permalink)
Rob,the 19mm is part of the axle.Just hold it still and loosen the 24mm.
Old 07-12-2009, 11:25 PM   #7 (permalink)
Yes, another member just pointed out that embarrassing fact to me also.
Thanks again Burner, very much appreciated!
Rob
Old 07-12-2009, 11:28 PM   #8 (permalink)
Legend
Favourite Bike: 904cc Bonnie w/magwheels
sweatmachine's Avatar
I heard/read/imagined they made each side of the axle need a different sized socket so you wouldn't have to buy another socket, provided you already had a socket set.
Old 07-12-2009, 11:32 PM   #9 (permalink)
That makes perfect sense now that you point it out. Sadly my Sears 140 piece set only goes to 20mm!!
Old 07-12-2009, 11:33 PM   #10 (permalink)
My old SL100 just had a chrome knob on one end with a hole in it,that you stuck a screwdriver into and then loosened the nut on the other end. I`m sure the axles on our bikes are set up so that the proper torque values can be applied.
19-Tooth Front Sprocket road dog Twins Technical Talk 110 07-15-2009 12:08 PM
New 19-Tooth Front Sprocket Stretch Tiger Mods & Bolt-Ons (archive) 22 08-28-2007 02:17 AM
Chain Lube again plus the 18 tooth sprocket TOMKRILL Twins Technical Talk 18 08-17-2007 02:50 PM
17 Tooth front sprocket! WOW! cyclerider105 Speed Triple Forum 36 07-27-2006 08:55 AM
17 tooth front sprocket. Where to get it. Hotmailjerk Speed Triple Forum 6 01-08-2006 12:04 PM
