Carbed bike? Sounds like water in the float bowl(s), I've had this happen before, water is denser than gas so it sits at the bottom of the float bowl where the main jet will pick it up but the idle jet/circuit will not.
I'm not up on this particular model, but it's it's got carbs I'd recommend draining some fuel from the floats and give that a shot.
