07-12-2009, 12:11 AM
Newbie with new Triumph...some questions
I just picked up a 2006 Scrambler with under 1000 miles.
Is there anything I need to be aware of with this bike? Any must do tips that need to be done like re-torque bolts and such...?
Also when I am off the throttle and go back on suddenly, is it normal to be jerky or should it be smooth. Chain is in spec...any advise would be great, as I am also reading as many threads as I can to help out.
07-12-2009, 12:26 AM
Site Supporter SuperStock Favourite Bike: Tiger 800 XC
Posts: 224 Other Motorcycle: Tiger 1050 Extra Motorcycle: Trophy 900
Just ride it ...
You should be smoother with the throttle ...
"Even if you are on the right track,
you'll get run over if you just sit there."
-- Will Rogers
07-12-2009, 12:32 AM
cool, my previus bike I had to torque a bunch of stuff and blue thread some things...also can anyone tell me if my 06' Scrambler was made in England or in some other country. Thanks
07-12-2009, 12:41 AM
Some other place - Thailand - All Bonnie derivitives made there since 05 ...
-- Will Rogers
07-12-2009, 12:49 AM
SuperStock Favourite Bike: T100 Bonneville
the jerky throttle is normal with the new EFI bikes.
07-12-2009, 03:00 AM
Site Supporter World SuperBike Favourite Bike: 2010 R3 Roadster
Serial number
Look at your 11th didgit in your ser #. If it is a T, your bike was assembles in Thailand, if not, you've got a real Brit bike.
I can't help believe this jerkiness is in some heads after they read so many threads. Before I started modifying my 09 T100, I liked the throttle response I was getting. But, being new, I started reading this forum like you and look what I did to a new bike with 3000 miles on her. Good luck and have a great day.
By the way, an AI removal will solve the jerky throttle problem. Just put a dog in your headers first to see if there are any hidden cats in there. This is a whole nother story.
07-12-2009, 06:34 AM
Supersport 600 Favourite Bike: '02 Bonneville
My throttle response could be considered "jerky." To say the least, it's very light on the touch. I have a poor man's cruise control on the twist-grip - a curved & cupped accessory, to rest the palm of your hand on. Well, each time I hit a bump, I get a "jerk" response from the throttle. I ended up adjusting this item downward, so my palm doesn't rest on it.
Previous owner of a beautiful
'02 Bonneville ... British Racing Green
Sold 28 Aug '09
Previous Motorcycles: R-51 & R-53 BMW; '58 Triumph TR6SR; '70 Honda 750.
07-12-2009, 06:38 AM
Supersport 600 Favourite Bike: T100 & Bmw R80st
Posts: 176 Other Motorcycle: BMW R 80st
The OP says that the bike is an 06, unless he meant 09 it will be carbs not EFI.
07-12-2009, 09:26 AM
Formula Extreme Favourite Bike: 2007 Scrambler 900
Posts: 411 Other Motorcycle: 2002 Vespa ET2
That's most likely just engine compression braking you are experiencing . Takes a bit to get used too .
The stock Trailwing tires are not good . I replaced mine at 4200 miles as the front tire was cupped and they sounded like a 4wheel drive truck going down the highway  . This tire change was the best mode I have done yet to date . The rear shocks are not to hot either .
Has it had the 600 mile service yet ? If not get that done . I like mine a lot . I like how tall it is , fits me well . But I am making it more bonnie like all the time
gl with your new ride
spro
Parabellum Scout screen , Triumph Tacho , V Max style mirrors , Gran Tourisimo Grips , Hepco & Becker Engine Guard , Rear Rack and , TopCase with BackRest , K&Q Triumph seat , Progressive 412-2460C rear shocks , and centerstand .
07-12-2009, 12:49 PM
Formula Extreme Favourite Bike: 08 T-100 Claret & Silver
Posts: 835 Other Motorcycle: TBD
Let me guess, your coming from a KLR-650? (I did)
Assembled in Thailand, same as the KLR.
Cheers,
Greg
2010 Thunderbird SE
