07-11-2009, 08:37 PM
SuperSport Favourite Bike: 04 Thruxton
Posts: 1,095 Other Motorcycle: BMW F800S
Changing my cams..
Currently in the process of removing my cams. I am trying to unbolt the bolts on the cam caps. I remember Prop once wrote he found them "F... tight". I cannot believe how tight they are. I have twisted my star drive socket trying to undo the bolts. My socket isn't some el cheapo socket but Sidchrome which should not twist. I know what some of you are thinking and no I am undoing them, not tightening them. Have others found the cam cap bolts real tight?? I am undoing the bolts gradually in a cris-cross manner...any other suggestions?
2004 Thrux, FCR39's, Uni filter, 813 cams, Works shocks, Ricor valves, progressive springs, Pieman ignitor, green springs, GT501s, Beringer caliper, predators, damper, fork brace, Corbin gunfighter, custom tinware, lowered instruments, JMC swingarm
07-11-2009, 09:31 PM
Site Supporter Legend Favourite Bike: 904cc Bonnie w/magwheels
Posts: 11,815 Other Motorcycle: 2005 Yamaha FZ1
yes they get tight! I use a good torx bit and a breaker bar if they're really tight.
07-11-2009, 10:06 PM
Site Supporter World SuperBike Favourite Bike: 1965 TR6SR
Posts: 1,914 Other Motorcycle: 2007 Scrambler
Sweat's right, get the best star bit you can. I wasted two average ones getting the cams out the first time. I even questioned the torque figures for tightening cause I thought there's no way these are at 10nm. Follow the loosening procedure in the manual because they are under spring tension from the valve springs. Go easy on those banjo bolts on re-assembly, they twist apart easily.
07-11-2009, 10:10 PM
not at TDC
07-11-2009, 10:32 PM
Loose Head Administrator
Site Supporter Supernova Favourite Bike: 2011 Tiger 800XC
Posts: 21,419 Other Motorcycle: 2007 Bonneville Big Carbs Extra Motorcycle: G12DL, ZX1100, KLR650
That is the precise level of tightness they are at. I couldn't believe it either - saw 10Nm spec, figured they'd be easy enough to remove - nah ah - no way. I almost had to use the impact wrench.
07-11-2009, 11:04 PM
Originally Posted by sweatmachine
not at TDC
I found it to be so, but I've got a 270 so might be different. I know the Haynes manual had a big bold caution statement that if the caps aren't loosened and removed correctly, the valve tension could snap the cams. Since I can't afford to break one, I err on the side of caution.
07-11-2009, 11:25 PM
Site Supporter SuperSport Favourite Bike: Bonnie Black Special
yep, that's how tight they are first time, I too twisted my star bit. But they're never that tight on subsequent removals. Must be a new engine expansion and contraction thing.
07-12-2009, 12:41 AM
Thx gents, relief to know I am not alone. In your opinions, what's the best quality tool brand in the US that I should shoot for when buying another star (torx) 30 socket? I am wanting to finish ripping out the cams tomorrow so I can post them on Monday....
07-12-2009, 01:00 AM
The good quality craftsman ones from sears should do it.
07-12-2009, 02:22 AM
I have a Craftsman T30 that I've used on my bike and a few others with no issues.
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Cams
GeneralPig |
Hinckley Classic Triples |
19 |
03-11-2009 08:30 PM |
bc cams?
ttbonnie |
Twins Technical Talk |
2 |
09-02-2007 05:10 PM |
tt cams
big2332 |
Triumph SuperSports |
5 |
03-09-2007 05:35 PM |
Wilcox cams...red cams green cams...???
Johnjohn |
12 |
08-28-2006 09:27 AM |
Cams (again)
Saigon5 |
5 |
03-28-2005 09:28 PM |
