Air Injection be gone DIY – 2009 EFI Bonny/Thrux - Page 62 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-08-2012, 01:15 PM   #611 (permalink)
Main Motorcycle: 2012 Scrambler
Luxlamf's Avatar
Other Motorcycle: 2002 VROD
Interesting, perhaps I will take this on myself, Thanks.
Luxlamf is offline   Reply With Quote
Old 12-25-2012, 08:58 PM   #612 (permalink)
Main Motorcycle: Speedmaster 2008 Custom
cancarl's Avatar
The Kit
Got a few things from British customs one being the AIK, got a few questions:
1, There are 4 nipples, where do they go?
2, 2screw type things one with two copper looking washer/gaskets
3, One other piece?
I can only see where you used one of these items and then you use a resistor that is not included in the kit which by the way is extremely rare in Canada (as in I can't find one......No Radioshacks here), • Online, backordered in US Radioshacks!!!
Have looked all over.
BC sent me to this site off their site to use your instructions!!!
Have asked them where their instructions are!
Hope you can help,
Thanks,
Carl
P.S.
I will also be doing the Airbox removal and the Bomber pipes at the same time.
cancarl is offline   Reply With Quote
Old 12-26-2012, 07:08 AM   #613 (permalink)
Main Motorcycle: Triumph Bonnie 2012
exlimeydedbt's Avatar
?????????? Radio Shack is now the source, in canada, i got one from there, still trying to figure out what goes what though, were do the conctions go to Bullits
exlimeydedbt is online now   Reply With Quote
Old 12-26-2012, 08:15 AM   #614 (permalink)
sprouty115's Avatar
You may have missed it, but Forchetto answered your question in post #605.
- Stephen
sprouty115 is online now   Reply With Quote
Old 12-26-2012, 08:37 AM   #615 (permalink)
sprouty115's Avatar
Wink
3, One other piece?
I can only see where you used one of these items and then you use a resistor that is not included in the kit...
Answers:
1 If you have a bike with carburators they are used to block the ports that are on the carbs. If you have an EFI bike you don't use them.
2 The threaded plugs are installed in the hole left by the SAI injectors when you remove them. The SAI injectors are next to the spark plugs.
3 The larger rubber plug goes in the hole in the left side of the airbox after you remove the tube that goes to the SAI valve body.
As for the resistor question: I have no idea who ships to Canada, but there must be more than Radio Shack as a source. Personally I would skip the resistor and go the Tune ECU route as you will most likely be headed down that path anyway based on the mods you're planning.
And one final thought: if I might be so bold and humbly suggest you grab a delicious La Fin du Monde and spend an hour going through this thread. You do have a lot of mods you are planning and there is a lot of useful info you will miss out on if you only read my abreviated response above.
Good luck.
- Stephen
Old 12-27-2012, 04:06 PM   #616 (permalink)
Thanks Stephen, Solinoid that has been cut,solder resistor to this? Just being care full, cooked a harness once,made me kinda jumpy.More speed less haste thing.
Old 12-27-2012, 04:32 PM   #617 (permalink)
sprouty115's Avatar
Basic answer is yes, but look at the second or third post of the thread it has all the info including pictures.
- Stephen
Old 12-27-2012, 06:36 PM   #618 (permalink)
Legend
Forchetto's Avatar
Also note that since this thread was started things have changed somewhat.
We've found that a much higher value resistor will also fool the ECU adequately. This means a much smaller resistor that can be fitted into the existing solenoid connector. Higher ohmic value=less heat generated=smaller physical size resistor.
We can also use software such as TuneECU to do the MIL light disabling, avoiding any sort of resistor.
Details of resistor values and fitting method on this post:
http://www.triumphrat.net/twins-tech...ml#post2157299
Forchetto is online now   Reply With Quote
Old 01-01-2013, 02:23 PM   #619 (permalink)
O by the way just a little thing, whenyou bend backwards and forward, the air tubes[Work harden]. squeeze the tubes tight just below,,,,,,,,,,bending, with needle knose plyers,Why? I used that trick years ago,taking apart steel air lines,noticed slivers of steel inside pipe, from break, would not be good in comb chamber
Old 01-01-2013, 02:42 PM   #620 (permalink)
Legend
Forchetto's Avatar
It needs a simple 13mm offset ring wrench for tube removal without damage:
The AI port doesn't go into the combustion chamber, however it ends up very close to the exhaust valves as can be seen towards the end of this excellent borescope video by Alighieri, so yes, any metallic debris in there is best avoided:
http://www.triumphrat.net/twins-tech...ml#post2460079
This is a still from that video, the AI inlet can be clearly seen :
2009 Bonny Bafflectomy....Fail... biker7 Twins Technical Talk 29 04-09-2012 11:31 AM
Clip-Ons for 2009 Thrux? THruXTonSOON Club Cafe' 12 06-23-2009 09:32 AM
A I removall on an injection bonny snowyrock Twins Technical Talk 7 06-08-2009 02:33 PM
clip on conversion for a 2009 Thrux mlc Club Cafe' 2 04-12-2009 06:12 AM
2009 Bonny T-100...Got it home...Pics biker7 Twins Talk 104 02-14-2009 09:40 PM
