06-12-2009, 09:18 AM
Newbie
twin spark bonnie
hi, i keen to share my idea for twin-sparking my bonneville by removing secondary air and threading the hole that is left to fit sparking-plug. Igniting any unburnt fuel is a good thing-think two stroke! Have spliced into existing HT lead with smaller wiring to create smaller secondary spark. result-more power, lower down torque and smoother delivery. Am thinking of using colder plug for secondary, but am pleased with reult so far so wll see.
06-12-2009, 09:26 AM
SuperBike Favourite Bike: '09 T-100
Hi and welcome to the forum. Quite an opening post.
Interesting. Is your bike fuel injected or carbed?
Why do you believe a cooler heat range for secondary plug would be beneficial?
I guess what is unclear to me is why a spark plug in that port would have any further benefit? Does anybody have a picture of the underside of the cylinder head showing the relationship of the AI threaded hole to the combustion chamber?
Cheers,
George
06-12-2009, 09:27 AM
Modolicious Moderator
SuperBike Favourite Bike: 2004 Speedmaster
Have you done a before and after dyno? What about emissions readings?
06-12-2009, 09:45 AM
SuperSport Favourite Bike: 2004 Thruxton
Posts: 1,330 Other Motorcycle: 1971 BMW R50/5 Extra Motorcycle: 1971 CB350
My experience with dual plugging bikes is limited to airhead bmws, where the dual plugging is performed to reduce detonation when bumping compression, where crap fuel is only available, or in lieu of fixing the real issue causing pinging in R60/5,6,7 variants. Traditional dual plugging on those machines placed the second plug 180 degrees from the primary plug port (in relation to the valves).
I'd be interested in seeing some sort of documented improvement in power development for this change...the plug & air injection port are right next to each other and, intuitively, doesn't seem like the ideal arrangement for a dual plug situation.
Cheers,
--Rich
06-12-2009, 10:25 AM
Site Supporter Legend Favourite Bike: 904cc Bonnie w/magwheels
Posts: 11,815 Other Motorcycle: 2005 Yamaha FZ1
you do know the air injection hole does NOT go to the combustion chamber, right? This would not work for a dual plug set up without significant machine work.
06-12-2009, 12:44 PM
Site Supporter SOTP Vintage Series Favourite Bike: Velocette Clubman
Posts: 7,019 Other Motorcycle: 2007 Bonnie Black Cafe Extra Motorcycle: 77 GS400
beat me to it Sweetmachine......
06-12-2009, 01:32 PM
Yeah but...that post ignition is like an afterburner.
06-12-2009, 01:34 PM
it's like....pointless
06-12-2009, 01:47 PM
Site Supporter SuperSport Favourite Bike: Bonnie Black Special
Sorry Rocktooee your seat of the pants dyno ain't working very well, you have no "more power, lower down torque and smoother delivery". What you do have is a compromised ignition system and a spark plug firing in the exhaust port.
You must have cut a thread in the AI holes for the spark plugs without removing the head, dangerous business if some of the swarf drops past open valves in to the chamber.
06-12-2009, 02:02 PM
Formula Extreme Favourite Bike: 2001 Sprint ST (Red)
Posts: 502 Other Motorcycle: 2007 T100 Red & Black Extra Motorcycle: 56 vespa, 03 atlantic etc
Unless there is some tiny plug that actually fits in that hole?? I've seen some small plugs on, say, weed wackers??
But yeah, his dyno is faulty... and the point of the AI kit is to REDUCE the burning of gasses in the exhaust. Maybe we're trying to make a HD note?
