07 bonneville center stand hits chain. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-11-2009, 12:44 AM   #1 (permalink)
Favourite Bike: TRIUMPH BONNEVILLE BLACK
redly40's Avatar
Other Motorcycle: '77 KWAKA KZ1000
HI Umm bit new to this.
Got a problem fitting my 07 bonny with a center stand (Norman Hyde).
I have after market pipes on it a bit like a thruxton (upswept "Emgo?" got em on ebay)
Anyway went to fit stand and found the stand hits the chain.
Was checking to see if anyone else had this problem or could supply an answer?
07 bonneville center stand hits chain.-pic_0153.jpg   07 bonneville center stand hits chain.-pic_0161.jpg
redly40 is offline   Reply With Quote
Old 06-11-2009, 01:23 AM   #2 (permalink)
Favourite Bike: 2001 Sprint ST (Red)
Other Motorcycle: 2007 T100 Red & Black
Extra Motorcycle: 56 vespa, 03 atlantic etc
On my T100, the left exhaust pipe has a flat bracket which stops the center stand retracting any further. You will need to fab a bracket that will stop the stand from retracting so far up. I think my center stand, when up, is just about flat with the ground. I don't know if there is another option - maybe a double S shape mounted on the pivot which contacted the vertical frame member and stood back into the travel of the stand would work.
I've looked at this as I've looked at aftermarket exhausts...
coldnight is offline   Reply With Quote
Old 06-11-2009, 08:23 AM   #3 (permalink)
Favourite Bike: Thrux
Other Motorcycle: Ducati SC1000
Had the same problem
I had the same problem when I fitted an arrow system to my Thruxton - not good news really, my dealer informed me after a few enquiries that the centre stand needs to be removed as it is not designed to fit with an aftermarket exhaust.
The only alternative as they saw it was to make up a bracket.
I now don't have it fitted
Regards Nick
Nick1000 is offline   Reply With Quote
Old 06-11-2009, 12:23 PM   #4 (permalink)
6t
Favourite Bike: The one that I am on
6t's Avatar
Other Motorcycle: 2002 Bonneville America
Extra Motorcycle: Honda RC30
I fitted a Scrambler exhaust to my T100 and had the same problem. Found a mod on here that worked great. If I can find it I'll post it, but maybe do a search and see what you come up with.
Found it, works great.
http://www.triumphrat.net/twins-talk...atest-mod.html
2002 T100 Anniversary. Lucifer Orange no more, "Scrambled"
Brakes and suspension, various Scrambler parts, speedo/tach in headlamp .
6t is online now   Reply With Quote
Old 06-11-2009, 12:31 PM   #5 (permalink)
Favourite Bike: 2007 Triumph Thruxton
blight's Avatar
Other Motorcycle: 2010 Harley XR1200
Extra Motorcycle: 1969 BSA 441 Victor
Hi, I had a similar problem with the OEM Triumph centerstand hitting my new 180 rear tire. I took an angle grinder and ground off the tiny portion of the foot (on both legs) that was hitting the widest edge of the tire as it was swinging past it.
I also put in a washer to eliminate the stand's side to side free-play so I know it won't move and rub the tire.
Pretty easy, and you can keep your stand! If you don't have an angle grinder, remove the stand and trim the area with a hacksaw, and file it smooth. Looks like a small trim is all that's needed by your photos.
Cheers!
BLIGHT
blight is offline   Reply With Quote
Old 06-11-2009, 05:10 PM   #6 (permalink)
Favourite Bike: Velocette Clubman
Calliway's Avatar
Other Motorcycle: 2007 Bonnie Black Cafe
Extra Motorcycle: 77 GS400
You guys, the only thing that stops your center stand from smacking the chain is the STOPPER that is attached to the left hand side of your exhaust.
Do you have the rubber bumper in the metal "l" bracket that should come off your exhaust mount?
If you make that bracket long enough the center stand will hit it instead of the chain. There are many aftermarket exhausts that dont seem to come with this so you may have to fab up a piece of aluminum to come down and stop the center stand. Where does your normal stand hit? The center stand should hit the same place.
Calliway is offline   Reply With Quote
Old 06-12-2009, 03:40 AM   #7 (permalink)
redly40's Avatar
Talking Thanks All !
Thanks guys for all ya help & info looks like I will run with 6T's suggestion (thanks 6T for goin to the trouble of finding that link mate! a picture sez a thousand words) tho will probably do both sides of the stand just to be sure.
This way the mod is hidden.
Happy biking to all and travel safe too!
Old 06-12-2009, 09:07 PM   #8 (permalink)
6t
6t's Avatar
[QUOTE=redly40;1291529] (thanks 6T for goin to the trouble of finding that link mate! a picture sez a thousand words) QUOTE]
Just passing it on, Inominate was good enough to pass Loxpump's mod on to me when I was in your situation, seems to be the way it works on here.
I see that you are in Queensland, I have an ex-mother-in-law there. I hope you never run into her, there's a reason I live where it gets COLD in winter
Old 06-12-2009, 09:20 PM   #9 (permalink)
Thumbs up Stand
Easy fix! Sell center stand on E-Bay & get a paddock stand instead? Will maybe have enuff left for a lift? The MOST valuable tool I have for my Bonne!! Think of the better looks & the weight loss!
CAPT D
chain lube with no center stand Vegas_07Bonnie Twins Technical Talk 32 03-10-2009 09:30 AM
Does the chain skip when run on center stand? MelUK Sprint Forum 11 10-09-2008 01:23 AM
Chain adjustment-center stand or side stand? andyc740 Trophy 7 04-02-2008 06:41 PM
Center Stand - Chain Clearance pjamesb80 Twins Technical Talk 5 12-08-2007 09:31 PM
Chain adjustment w/center stand danbike Twins Talk 9 04-21-2006 10:09 AM
