Originally Posted by evalu8or
... My 04 Thruxton went in for its 50,000 km service and my Triumph dealership just told me the regulator/rectifier is going. ...
Can you explain what your dealer meant by 'going' ?
Can you describe the symptom please?
My experience is these either work or are 'gone!' There is no 'going', they don't go 'soft' or anything of a nature that is only 'partially' functioning, or capable of putting out less volts than it should.
If output charging voltage is 'low' this is more typically indicative of a stator which has one burned phase. Or a shorted diode or SCR in the rectifier stage - both of these could only be considered already bad.
The other failure mode would be high output volts - not regulating - bad R/R in that instance, would also consider that 'gone'.
Before you commit any money to replacement parts, perhaps you would like to run through the diagnostics in the
above referenced thread.
Having said that, the MOSFET R/R is an excellent upgrade regardless - just to be sure that you don't end up still chasing a bad stator, so an accurate diagnosis of your problem would be good.
